Convert jpg to tif - arcpy
16305
27
03-30-2015 07:39 AM
Yaron_YosefCohen
Hi
I have several rasters( jpg files ) and i want convert them to tif files to file " OtherFormat" in env.workspace with arcpy. In my code i try to convert all jpg file:
import arcpy,os,sys,string
import arcpy.mapping
from arcpy import env
env.workspace = r"C:\Project\out"
arcpy.RasterToOtherFormat_conversion("*.jpg","OtherFormat","TIFF")
print 'converted'
but get en error:
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Rasters: Dataset *.jpg does not exist or is not supported
Failed to execute (RasterToOtherFormat).
any help would be great
Yaron_YosefCohen
Hi Xander,
i run the code with this changes :
in_folder = r"C:\Project\out"
out_folder = r"C:\Project\out\jpg"
and the result:
[u'BSM-1534.tif']
BSM-1534.tif
and no converted rasters in the out folder. I don't know why the code don't convert- it seems right and clear
Yaron_YosefCohen
Hi Xander,
i don't know why it's wrong. i get result:
[u'BSM-1534.tif']
BSM-1534.tif
and the raster didn't converted
XanderBakker
Esri Esteemed Contributor
I have no idea... the code worked for me on my sample data.
Maybe you can attach the mentioned TIF so I can see what it's like?
Yaron_YosefCohen
the tif raster size is more than 500 mega.how can i send it and to which email?
by the way, i succeed convert jpg to tif but when i try tif2jpg it don't work.
and more important to me to convert ecw to jpg. in ArcGIS Help (10.2, 10.2.1, and 10.2.2)
i don't see any mention to ecw file
DanPatterson_Retired
Try it with a smaller size tif to see if it image size (which I suspect, or a corrupt tif)
Convert the ecw to another format in the originating software if you have it
Yaron_YosefCohen
you right!!  i tried with smaller  size tif raster and tif2jpg succeed.
but when i tried  ecw2tif the python stop working. could you know way?
Yaron_YosefCohen
i don't have originating software. can you recommend one please?
google " ecw to tif "  there are purportedly free converters and trial versions online if ArcMap doesn't support ecw
