codeblock @ arcpy.CalculateField_management
1642
10-11-2013 01:32 AM
MarkusSchnitzius
I have a table named "street" with a column named "Kategorie", filled with values "0..6". I added a new column named "RULE". I want to fill this column with strings depending on "KATEGORIE". I have a PY-Script and it doesn't work. What is wrong.
I think the problem is the line "expression" or "codeblock". I try to print the result of "myval".The result is a error message "name myval is not defined"
Thank you for your help !
expression = "getKat(!KATEGORIE!)"
codeblock = """def getKat(KATEGORIE):
    if KATEGORIE == "0":
        myval == "Autobahn"
    elif KATEGORIE == "1":
        myval == "Bundesstrasse"
    else:
        myval == "3"
    return myval"""
print "myval", myval
arcpy.CalculateField_management(ERG, "RULE", expression, "PYTHON", codeblock)
StephanieWendel
It looks like you were actually not assigning any values to myval. You had the double equals sign which is used to test equality not assign values. Try your code like this:
        myval = "Autobahn"
        myval = "Bundesstrasse"
    else:
        myval = "3"
    return myval"""
