Clipping polygons in a shapefile
708
02-23-2012 04:40 AM
JeffreyVu
I have posted this question in the Editing forum but I thought this would be done in Python.
I have several polygons in a shapefile with the Priority field. Is it possible that we can write Python code to clip the polygons based on this field?
Thanks in advance.
Jeffrey
MathewCoyle
Honored Contributor
So you want to clip one polygon layer based on say priority = 1 of your other polygon layer, or clip based on each possible priority in the feature class? Yes you can do that.
Make a feature layer with a where clause of the features you want to clip
Clip
Enclose in a for loop if you want to do different where clauses base on variable values.
