Clear Selected Features in All layers
8344
6
04-11-2013 10:24 AM
TimWitt
I am looking for a way with python to clear all selected features in my dataframe. Like the "Clear Selected Features" button in ArcMap.
I have been looking for this online and just could not find it.
The only thing I can find is SelectLayerByAttribute_management(in_layer_or_view,"CLEAR_SELECTION")
The problem there is, that I need to feed it a specific layer, but I want to clear the selection in every layer.
Anyone know the answer?
ChristopherBlinn1
Have you tried looping through your layers in your dataframe?
for lyr in arcpy.mapping.ListLayers(mxd,"",df):   SelectLayerByAttribute_management(lyr,"CLEAR_SELECTION")
That should take each layer in your dataframe and clear any selected features.
Hope this helps!
Best,
Chris B.
ChristopherBlinn1
Hope this helps!
Best,
Chris B.
TimWitt
It works, but it slows  down my script a lot since I have 40 layers in my mxd.
I was just surprised I couldn't find anything, since there is a button that clears everything.
MathewCoyle
Honored Contributor
That is available through ArcObjects, not arcpy.
http://forums.esri.com/Thread.asp?c=93&f=992&t=274217
TimWitt
But is there anyway to achieve the same in arcpy?
MathewCoyle
Honored Contributor
Yes... Christopher's answer.
PhilLarkin1
Pro solution:
aprx = arcpy.mp.ArcGISProject("CURRENT")
map = aprx.listMaps('Your Map')[0]
map.clearSelection()
Map—ArcGIS Pro | Documentation
