Check for certain field name and field type doesn't work
1196
02-01-2023 11:39 PM
JohannesBierer
I want to check if a field type is text to change this field to type double so that I can use it as input field into XYTableToPoint?
This if statement in line 16 doesn't work (arcgis pro 3.0 notebook)
Any ideas?
Error message for line 41:
ERROR 000308: Ungültiger Feldtyp
for f in files_list:
    print (f)
    outTable = "tab_" + os.path.splitext(os.path.basename(f.replace("-", "_")))[0]
    outXY =  "s_" + os.path.splitext(os.path.basename(f.replace("-", "_")))[0]
    arcpy.conversion.ExcelToTable(f, outTable)
    x = "R_Wert"
    y = "H_Wert"
    fields = arcpy.ListFields(outTable)
    field_names = []
    for field in fields:
        field_names.append(field.name)
        if field.name == x and field.type == "TEXT":
            print("Wrong type")
            arcpy.management.AddField(outTable, "R_Wert_1", "DOUBLE")
            arcpy.management.CalculateField(outTable, "R_Wert_1",
                                '!R_Wert!', "PYTHON3")
            x = "R_Wert_1"
        elif field.name == y and field.type == "TEXT":
            print("Wrong Type")
            arcpy.management.AddField(outTable, "HWert_1", "DOUBLE")
                                '!H_Wert!', "PYTHON3")
            y = "H_Wert_1"
        else:
            continue
    if x in field_names and y in field_names:
        print("Field names ok")
        arcpy.management.XYTableToPoint(outTable, outXY,
                                        x, y, "",
                                        arcpy.SpatialReference("DHDN 3-Degree Gauss Zone 3"))# ('ETRS 1989 UTM Zone 32N'))
    else:
        print("Field names wrong")
        continue
JohannesLindner
MVP Alum
Field—ArcGIS Pro | Dokumentation
Although the Field object's type property values are not an exact match for the keywords used by the Add Field tool's field_type parameter, all of the Field object's type values can be used as input to this parameter. The different field types are mapped as follows: Integer to LONGString to TEXT, and SmallInteger to SHORT.
if field.name == x and field.type == "String"
Have a great day!
Johannes
JohannesLindner
MVP Alum
Have a great day!
Johannes
JohannesBierer
Thank you ...
