Check Box to make additional field available ArcPro Tool Box
818
03-02-2020 08:12 AM
by Anonymous User
Not applicable
Hello what I would like in an ArcPro Tool Box is a checking a box make addition arcpy.GetParameterAsText field visible  that were not visible before checking the box.  Is there a snippets out there please? Thx
DanPatterson_Retired
Why not specify that the parameter can use multivalues
Parameter—ArcPy classes | Documentation
This can be done in code or through the dialog wizard if you are using custom toolboxes
It will then look like this in the tool dialog
