Change Raster rendering to "composite RGB"
899
07-21-2011 05:29 AM
GuillaumeMOCCAND
Dear all,
i need to load a Raster (jp2) in a mxd but without using lyr files.
here is my code (it works fine)
mxd2 = arcpy.mapping.MapDocument(mxdTemplate)
df2 = arcpy.mapping.ListDataFrames(mxd2)[0]
addlayer = arcpy.mapping.Layer("c:\toto.jp2")
arcpy.mapping.AddLayer(df2, addlayer, "BOTTOM")
rasterExtent = addlayer.getExtent()
df2.extent = rasterExtent
mxd2.saveACopy (nouveauMXD)
but the Raster is rendered "streched" ... i need to get it as it should : in composite RGB.
Any idea about doing this in arcpy ?
Thanks in advance
Guillaume
GraceCHUNG
Have you found out the solution? I am having the same problem.
I want to add a "tif" with "RGB Composite", not single band image.
Any help will be appreciated.
