cannot open workspace error when python script is called from a DevOps pipeline.
1207
05-04-2023 08:46 AM
speaktoandrew2023
I'm at my wits end with this. (hence the post).
I've got a python script which will connect to a SQL database and insert some records.
I call this python script from a Powershell window and it works fine and inserts the records as required.
I call this same python script from an Azure DevOps pipeline ie from a powershell script and this time it throws an error on the line
edit = arcpy.da.Editor(connection)
The error is : "cannot open workspace"
The only difference being the pipeline opens a remote session onto the machine and then calls the python script.
Could this be the reason for this behaviour? I have added "import arcserver" to the python script but this hasnt fixed the issue.
I know I havent given much but I'm looking for possible issues to explore.
RhettZufelt
MVP Notable Contributor
No familiar with Azure DevOps pipeline, but what is the value of "connection" in your script?
Just a thought that maybe it is to a mapped drive that doesn't get "mapped" when connecting with the pipeline instead of logging in locally?  If so, perhaps absolute paths would resolve it?
R_
speaktoandrew2023
Thanks for taking the trouble to reply. I've printed the connection variable and it is a full path to the  . sde file.
