Can you add a Chart Guide using Python (ArcGIS Pro 2.9)
1285
01-10-2022 12:17 PM
AndyWells
I have some Python codes that runs in ArcGIS Pro to create a bar chart for a layer. The only thing I can't figure out is how to create a chart guide. It is possible to do it in ArcGIS Pro using the GUI, but is that functionality available through arcpy?
DanPatterson
MVP Esteemed Contributor
As you probably already know, this is the charts access
What is the Charts module—ArcGIS Pro | Documentation
and I didn't see anything in the CIM either
... sort of retired...
AndyWells
Yes, I went through that documentation quite a bit. It would be a shame if you can't do these types of things through python. So I hope to find some way to do it, because the functionality of the charts I need rely on being able to show that guide area.
DanPatterson
Sounds like an "Idea" ... if you want to happen, you should propose it or support an Idea that might already exist
