Can't view created feature class
3893
11
12-14-2011 02:42 PM
BartKowalski
I've written a script that connects to a SQL Server via pyodbc, and creates a feature class from a table. The code runs fine, but one in Arc, I don't see my feature class, although the attributes are all there. I am new to python, and can't figure out what I am missing.
import arcpy
#reload(arcpy)
import pyodbc
from arcpy import env
cnxn = pyodbc.connect('Driver={SQL Server Native Client 10.0};UID=ID;PWD=Password;SERVER=spk-db11sac.spk.ds.usace.army.mil; DATABASE=ftord; APP=MyApp')
cursor=cnxn.cursor()
cursor.execute("select aquifer, site_id, well_name, station_name, well_type, welltype_desc, northing, easting, coord_source, toc, ground_elev, top_screen_depth, bot_screen_depth, total_depth, diameter, installer, date_inst, date_aban, destroyed, purge_vol, norm_dtw, pump_depth, comments, well_status, destruction_rationale, date_destroyed, ref_document, destruct_permit_number from dbo.Wells_view")
rows = cursor.fetchall()
env.overwriteOutput = True
env.workspace = r"G:\Fort_Ord_GIS\Master_Coverage\Fort_Ord.gdb"
template = r"G:\Fort_Ord_GIS\Master_Coverage\Fort_Ord.gdb\improvement_well\water_well_point"
Wells = arcpy.CreateFeatureclass_management(r"G:\Temp\Bart\scratch.gdb", "ODB11", "POINT",'', "DISABLED", "DISABLED", template)
#arcpy.AddField_management(Wells,'SubTypeIdentifier','TEXT')
arcpy.AddField_management(Wells,'PKWellID','TEXT')
arcpy.AddField_management(Wells,'PKMApID','TEXT')
arcpy.AddField_management(Wells,'FKMetalID','TEXT')
arcpy.AddField_management(Wells,'FKMediaID','TEXT')
arcpy.AddField_management(Wells,'FKCoordbtID','TEXT')
arcpy.AddField_management(Wells,'FKMnwellID','TEXT')
arcpy.AddField_management(Wells,'WellCatDOM','TEXT')
arcpy.AddField_management(Wells,'WellTypDOM','TEXT')
arcpy.AddField_management(Wells,'WellStaDOM','TEXT')
arcpy.AddField_management(Wells,'CaseMatDOM','TEXT')
arcpy.AddField_management(Wells,'ConstTyDOM','TEXT')
#arcpy.AddField_management(Wells,'HoleDia','TEXT')
arcpy.AddField_management(Wells,'DiaUOM','TEXT')
#arcpy.AddField_management(Wells,'Depthto1st','TEXT')
#arcpy.AddField_management(Wells,'Depthtowat','TEXT')
#arcpy.AddField_management(Wells,'Depthtobdk','TEXT')
#arcpy.AddField_management(Wells,'Totaldepth','TEXT')
#arcpy.AddField_management(Wells,'ReferElev','TEXT')
#arcpy.AddField_management(Wells,'ElevUOM','TEXT')
arcpy.AddField_management(Wells,'DepthUOM','TEXT')
#arcpy.AddField_management(Wells,'Capacity','TEXT')
arcpy.AddField_management(Wells,'CapacUOM','TEXT')
arcpy.AddField_management(Wells,'FKWpumpID','TEXT')
arcpy.AddField_management(Wells,'FKTankID','TEXT')
arcpy.AddField_management(Wells,'FKInstInID','TEXT')
arcpy.AddField_management(Wells,'FKBuildngID','TEXT')
arcpy.AddField_management(Wells,'FKProjectID','TEXT')
arcpy.AddField_management(Wells,'FKStationID','TEXT')
arcpy.AddField_management(Wells,'FKFulzoneID','TEXT')
arcpy.AddField_management(Wells,'FKWatsectID','TEXT')
arcpy.AddField_management(Wells,'FKGaszoneID','TEXT')
arcpy.AddField_management(Wells,'FKHcszoneID','TEXT')
arcpy.AddField_management(Wells,'FKStosectID','TEXT')
arcpy.AddField_management(Wells,'Narrative','TEXT')
Wcur = arcpy.InsertCursor(Wells)
for row in rows:
        #print row.well_name
        t_row = Wcur.newRow()
        t_row.PKWellID = row.well_name
        t_row.WellStaDOM = row.welltype_desc
        Wcur.insertRow(t_row)
#for row in rows:
        #t_row = Wcur.newRow()
        #t_row.PKWellID2 = row.station_name
        #Wcur.insertRow(t_row)
cnxn.commit()
cursor.close()
cnxn.close()
del row
del rows
del cursor
del cnxn
Help greatly appreciated in advance.
BArt
JakeSkinner
Esri Esteemed Contributor
I've seen some hiccups with the overwriteOutput command after scripts have been executed and then it's added.  Try deleting the table, restarting Pythonwin/IDLE, and then re-execute the script.
HemingZhu
env.overwriteOutput =true  has no impact on arcpy.FeatureClassToFeatureClass_conversion.  Either use arcpy.CopyFeatures_management, or delete feature class prior to arcpy.FeatureClassToFeatureClass_conversion. Something like this:
outFC =outLocation +os.sep + outFeatureClass
#need import os. (or use out FC =outLocation +"\\"+ outFeatureClass)
if arcpy.Exists(outFC)==True:
          arcpy.Delete_management(outFC)
