Can't Set default boolean value in python toolbox
1931
01-31-2018 04:11 PM
ShaneFeirer
I know that this had been asked before, But the simple examples have not worked.  I am including the pyt code in the message to help illustrate the issue.  If I use the line param6.value = True, the python toolbox will not load, but if I comment out that line it loads fine.  How should I be setting that boolean value on load to be checked.
import arcpy
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Toolbox"
self.alias = ""
# List of tool classes associated with this toolbox
self.tools = [Tool]
class Tool(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "Vector Prep"
self.description = "This tool is a first test of a python toolbox and tool"
self.canRunInBackground = False
def getParameterInfo(self):
#Define parameter definitions
# First parameter
param0 = arcpy.Parameter(
displayName="Stream Flow Database",
name="FlowDatabase",
datatype="DEWorkspace",
parameterType="Required",
direction="Input")
# Second parameter
param1 = arcpy.Parameter(
displayName="Model Name",
name="ModelName",
datatype="GPString",
direction="Input")
# Third parameter
param2 = arcpy.Parameter(
displayName="Workspace",
name="Workspace",
direction="Input")
# Fourth parameter
param3 = arcpy.Parameter(
displayName="DEM",
name="DEM",
datatype="GPRasterLayer",
direction="Input")
# Fifth parameter
param4 = arcpy.Parameter(
displayName="Regions",
name="Regions",
datatype="GPFeatureLayer",
direction="Input")
# Sixth parameter
param5 = arcpy.Parameter(
displayName="Precipitation",
name="Precipitation",
direction="Input")
# Seventh parameter
param6 = arcpy.Parameter(
displayName="Include Stream Network",
name="SteamNetwork",
datatype="GPBoolean",
parameterType="Optional",
direction="Input",
category="Optional")
#param6.value = True
# Eigth parameter
param7 = arcpy.Parameter(
displayName="Acre Threshold",
name="AcreThreshhold",
datatype="GPDouble",
direction="Input",
category="Optional",
enabled="False")
# NinthSeventh parameter
param8 = arcpy.Parameter(
displayName="Scale Precip. by Gauge",
name="ScaleGuage",
direction="Input",
# Tenth parameter
param9 = arcpy.Parameter(
displayName="Gauge Layer",
name="Gauges",
direction="Input",
enabled="False")
# Eleventh parameter
param10 = arcpy.Parameter(
displayName="Run Reservoir Model",
name="ReservoirModel",
direction="Input",
# Tweth parameter
param11 = arcpy.Parameter(
displayName="Reservoir Layer",
name="Reservoirs",
direction="Input",
enabled="False")
# Thirteenth parameter
param12 = arcpy.Parameter(
displayName="Run Water Rights Model",
name="WRModel",
direction="Input",
# Fourteenth parameter
param13 = arcpy.Parameter(
displayName="Water Rights Layer",
name="WaterRights",
direction="Input",
enabled="False")
# Fifteenth parameter
param14 = arcpy.Parameter(
displayName="Run Demand Model",
name="Demand",
direction="Input",
# Sixteenth parameter
param15 = arcpy.Parameter(
displayName="Structures Layer",
name="Structures",
direction="Input",
enabled="False")
# Seventeenth parameter
param16 = arcpy.Parameter(
displayName="Vineyards Layer",
name="Vineyards",
direction="Input",
enabled="False")
params = [param0, param1, param2, param3, param4, param5, param6, param7, param8, param9, param10, param11, param12, param13, param14, param15, param16]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
def execute(self, parameters, messages):
"""The source code of the tool."""
return
DanPatterson_Retired
Shane, perhaps you could re-paste the code using Code Formatting....
it is a bit hard to follow without the indentation
ShaneFeirer
Re-paste with code formatting...
import arcpy
    def __init__(self):
        .pyt file)."""
        self.alias = ""
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        self.description = ""
        # First parameter
            displayName = "Stream Flow Database",
            name = "FlowDatabase",
            datatype = "DEWorkspace",
            parameterType = "Required",
            direction = "Input")
        # Second parameter
            displayName = "Model Name",
            name = "ModelName",
            datatype = "GPString",
        # Third parameter
            displayName = "Workspace",
            name = "Workspace",
        # Fourth parameter
            displayName = "DEM",
            name = "DEM",
            datatype = "GPRasterLayer",
        # Fifth parameter
            displayName = "Regions",
            name = "Regions",
            datatype = "GPFeatureLayer",
        # Sixth parameter
            displayName = "Precipitation",
            name = "Precipitation",
        # Seventh parameter
            displayName = "Include Stream Network",
            name = "SteamNetwork",
            datatype = "GPBoolean",
            parameterType = "Optional",
            direction = "Input",
            category = "Optional")
        param6.value = True
        # Eigth parameter
            displayName = "Acre Threshold",
            name = "AcreThreshhold",
            datatype = "GPDouble",
            category = "Optional",
            enabled = "False")
            displayName = "Scale Precip. by Gauge",
            name = "ScaleGuage",
        # Tenth parameter
            displayName = "Gauge Layer",
            name = "Gauges",
            enabled = "False")
            displayName = "Run Reservoir Model",
            name = "ReservoirModel",
        # Tweth parameter
            displayName = "Reservoir Layer",
            name = "Reservoirs",
            enabled = "False")
            displayName = "Run Water Rights Model",
            name = "WRModel",
            displayName = "Water Rights Layer",
            name = "WaterRights",
            enabled = "False")
            displayName = "Run Demand Model",
            name = "Demand",
            displayName = "Structures Layer",
            name = "Structures",
            enabled = "False")
            displayName = "Vineyards Layer",
            name = "Vineyards",
            enabled = "False")
        return params
        return True
        return
        return
        return
