Can't import arcpy within Flask
2841
10-07-2020 06:25 AM
AndreV
I set up FastCGI in IIS and got the HelloWorld.py working properly. I also cloned conda env with Python-Package-Manager inside ArcGIS Pro for installing further 3rd party packages like pyodbc, etc. Inside my Flask.app I can't import arcpy, though all necessary paths are listed in sys.path. Everything I get is 500 Internal Server Error, nothing else.
I think I have to activate the conda environment, right?
I can successfully import arcpy within a standalone script and run it in VS Code Terminal. There, it seems to activate the conda environment BEFORE running the script. I see <PYTHONPATH>/activate.bat in the Terminal. It also works per cmd. So my question is, how do I activate the conda env before running the flask script?
Is there another way to use arcpy from arcgis pro with flask?
Any help is appreciated.
Andre
gdi-hohenlohekreis.de
AndreV
Solved the problem with the help of this post https://community.esri.com/thread/260581-are-wfastcgi-python-api-compatible#comment-956114
Problem was with NTFS-Permissions.
