Can not create polygon from text file with ID , X, Y, values in Python
11407
12
05-18-2016 12:19 AM
SadanandacharB1
Hi Everyone,
  I am new to Python, I am creating one empty feature class using python code and trying to create polygon using text file which is having ID, X, Y values as below,
my text file points.txt and the code is as follows
1 542935 1619969
2 543015 1619964
3 543079 1619924
4 543095 1619896
5 543107 1619816
6 543099 1619768
7 543067 1619669
8 543047 1619629
9 543007 1619593
10 542979 1619577
11 542923 1619569
12 542883 1619577
13 542810 1619625
14 542738 1619649
15 542698 1619701
16 542690 1619733
17 542699 1619773
18 542719 1619821
19 542775 1619893
20 542883 1619953
21 542935 1619969
>>> import arcpy, fileinput, string, os
>>> from arcpy import env
>>> env.workspace = "D:/Data"
>>> inputfile = "D:/Data/points.txt"
>>> fc = "newpoly.shp"
>>> arcpy.CreateFeatureclass_management("D:/Data", fc, "polygon")
<Result 'D:\\Data\\newpoly.shp'>
>>> cursor = arcpy.da.InsertCursor(fc, ["SHAPE@"])
>>> array = arcpy.Array()
>>> point = arcpy.Point()
>>> for line in fileinput.input(inputfile):
...     point.ID, point.X, point.y = string.split(line, " ")
...     array.add(arcpy.Point(X, Y))
...     cursor.insertRow([arcpy.Polygon(array)])
...     fileinput.close()
...     del cursor
But it is unable to create polygon feature, after running the code "newpoly.shp" is empty with values like
FID Shape Id
0   Polygon 0
where am i wrong?, why it is not writing geometry, Please help me
Thanks You
Sadananad
SadanandacharB1
Thank You So Much
SadanandacharB1
Thank You So Much
SadanandacharB1
Thank You So Much
