Can I place a line on a point using an attribute for the angle?
5923
07-24-2015 12:59 PM
KristineMuma
I have a set of points that I need to label in another software that has very limited labeling capabilities. We really need to be able to rotate the label by an attribute that we store. We came up with the desire to be able to place a line on that point of a predefined length and set the direction of the line to be in the angle of the rotation field. Has anyone ever attempted this?
WesMiller
KristineMuma
Unfortunately Annotation is not an option. And using the annotation polygon isn't working because anything that is a single digit is labeling incorrectly or not at all in this third party software. We are extremely disappointed that this was not going to work! Thanks
DarrenWiens2
Here's a script that should do what you're after:
>>> newLines = []
... points = "grid_label"
... angleField = "OID"
... lineLength = 300
... sr = arcpy.Describe(points).spatialReference
... with arcpy.da.SearchCursor(points,["SHAPE@",angleField],spatial_reference=sr) as cursor:
...     for row in cursor:
...         x1 = row[0].centroid.X + (math.sin(math.radians(row[1]))*(lineLength/2))
...         y1 = row[0].centroid.Y + (math.cos(math.radians(row[1]))*(lineLength/2))
...         x2 = row[0].centroid.X - (math.sin(math.radians(row[1]))*(lineLength/2))
...         y2 = row[0].centroid.Y - (math.cos(math.radians(row[1]))*(lineLength/2))
...         newLine = arcpy.Polyline(arcpy.Array([arcpy.Point(x1,y1),arcpy.Point(x2,y2)]),sr)
...         newLines.append(newLine)
... arcpy.CopyFeatures_management(newLines,r'in_memory\lines')
KristineMuma
Thanks Darren! I am so new to Python I knew I didn't have time to attempt to figure it out on my own. I can't wait to try this....
>>> Darren Wiens <[email protected]> 7/24/2015 4:29 PM >>>
GeoNet
( https://community.esri.com/?et=watches.email.thread)
reply from Darren Wiens
( https://community.esri.com/people/dkwiens?et=watches.email.thread) in Developers - View the full discussion
( https://community.esri.com/message/538527?et=watches.email.thread#538527)
>>> newLines = []
... with arcpy.da.SearchCursor(points,["SHAPE@",angleField]) as cursor:
... newLine = arcpy.Polyline(arcpy.Array())
https://community.esri.com/servlet/JiveServlet/downloadImage/2-538527-118816/pastedImage_0.png
( https://community.esri.com/servlet/JiveServlet/showImage/2-538527-118816/pastedImage_0.png)
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in Developers by email
( mailto:[email protected]) or at GeoNet
( https://community.esri.com/choose-container.jspa?contentType=1&containerType=14&container=2030&et=watches.email.thread)
Following Can I place a line on a point using an attribute for the angle?
( https://community.esri.com/message/538527?et=watches.email.thread#538527) in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe
( https://community.esri.com/unsubscribe.jspa?email=kmuma%40peterborough.ca&token=ddc1f5090c4eb13f98ad6c7c0516de919c7f5c29e1486eca3c3d526bae9eca83) instantly from GeoNet, or adjust email frequency in your email preferences
( https://community.esri.com/user-preferences!input.jspa)
