Can ARCGIS generate python code and if so how does it work?
2993
08-22-2013 08:17 AM
BarryBarrios
Like the "macro recorder" of Excel, can all your manual actions in ArcMap data view be instantly translated in Python commands? If so, how does it work. Honestly, I don't know where to start. I don't see a record button in none of the menu options. Someone told me it could be done.
StephenBugge
I know that you can use the Model Builder to create process models and then export those to a Python script.  I am not aware of a feature that operates like the Macro Recorder offered in the MS Office applications however.  Using the model builder may be a good way to start.
BarryBarrios
How do I use the Model builder to create process models and export to a python script? I don't know what the first step will be. Any simple example of how to use the Model Builder for this purpose is greatly appreciated. Even a screenshot or a video recorder showing how to do it, will be great.
StephenBugge
Suppose I want to generate buffers around the bus stops in this city to show the areas affected by a new anti-smoking ordinance, I'm going to use the model builder to do this even though this is a basic operation you would probably just use the tool to do in normal circumstance.
[ATTACH=CONFIG]26892[/ATTACH]
Once you have Model Builder Open, you can drag tools from the tool box in to it to add them to your model
[ATTACH=CONFIG]26895[/ATTACH]
DoubleClick on the Buffer Tool to open the tool dialog
[ATTACH=CONFIG]26896[/ATTACH]
I'm doing a 25 foot buffer around the bus stop points
Finally I am going to export to a Python Script:
[ATTACH=CONFIG]26897[/ATTACH]
Hope this helps
