Calculating Date for ArcSDE gdb - not getting Hours, Minutes, Seconds
776
05-07-2012 09:10 AM
SaraShullaw
Hello,
I'm trying to calculate a date field for a feature class in an ArcSDE gdb using Python. My script successfully calculates the year, month, day but only calcs zeros for hours minutes seconds. Can you help? Here is the relevant portion of my script:
# Import system modules
import arcpy, os, sys
from arcpy import env
import datetime
nowDate = datetime.datetime.now()
dateExp = nowDate.strftime("%Y-%m-%d %H:%M:%S")
arcpy.CalculateField_management("selectLyr", "UpdDate", "date '" + dateExp + "'", "", "")
DavidWynne
Hi Todd,
You could use the datetime object directly, sort of like below
arcpy.CalculateField_management("selectLyr", "UpdDate", `datetime.datetime.now()`, "PYTHON")
-Dave
Note: I'm using backtick's around the datetime when pushing it into the tool (just stating this in case that isn't obvious)
