Calculate percentage then round
4916
6
01-18-2016 09:13 AM
JudsonCrouch1
I am very new to Python but need to write a script to add 20% to a field and then round that number with the 20% to the next 50. I have figured out the calculations but for the life of me can't figure out how to put them together to get it into one function.
I've tried this in the code block:
def boom_length(boom):
    twenty_percent = ((!LENGTH_FT!) * 0.2) + !LENGTH_FT!)
    math.ceil(twenty_percent + (50 - twenty_percent) % 50)
    return twenty_percent
then in the expression:
boom_length(!BOOM_LEN!)
Thanks in advance for the help!
XanderBakker
Esri Esteemed Contributor
...and to explain the reason for these changes:
  • you have to import math to be able to use it (I think)
  • The function will have no knowledge of the field !LENGTH_FT!, so you have to use the parameter "boom" instead
  • There were some problems with unpaired brackets
  • You have to assign the result of the math.ceiling to the variable you return or simply say:
return math.ceil(twenty_percent + (50 - twenty_percent) % 50)
JoeBorgione
I'm no python expert by any means but have you looked at the round() method?
http://stackoverflow.com/questions/17470883/how-to-round-to-two-decimal-places-in-python-2-7
That should just about do it....
XanderBakker
Try this:
    import math
    twenty_percent = boom * 0.2 + boom
    twenty_percent = math.ceil(twenty_percent + (50 - twenty_percent) % 50)
XanderBakker
JudsonCrouch1
I think this is on the right track but it does not pull the value to add 20% to from the field "LENGTH_FT". My mistake...I should have mentioned that in the original post. I need it to pull a value from the field "LENGTH_FT", add 20% to it, then round that number up to the nearest 50 and store it in the field "BOOM_LEN"
XanderBakker
Assign the ouput to the field !BOOM_LEN!, but use the field !LENGTH_FT! as parameter in the expression:
in the expression:
boom_length(!LENGTH_FT!)
JudsonCrouch1
Thanks for the help! I was thinking too much about it...simple solution.
