Buffering Multiple feature classes in GDB (python)
16968
27
05-08-2015 07:55 AM
EthanHeidtman
I am having trouble buffering multiple feature classes within a GDB. These feature classes were just created based on a select by attribute and copy features tool run.
I have attached a copy of my script. The buffer analysis begins at the bottom, I have tried various parameters and dont know the variable that will be my input features that are the selected krogers from each county.
Thanks a lot!
Tags (3)
IanMurray
Honored Contributor
I was channeling my inner Dan Patterson​ for this topic.  I tend to just answer questions, but as you are a fellow student, I figured this was a good learning opportunity and you'd get more out of it by getting advice and working out most of it yourself.
I would like to reinforce the value of using model builder to design workflows convert them to python, then using python to augment it and make it much more valuable.  It becomes a much easier way to set-up scripts and saves the time looking up the proper syntax for many of the geoprocessing operations you are likely to use.
Glad you feel you have a better understanding now and good luck on your future work!
EthanHeidtman
I will definitely look into model builder, we touched on it briefly in class. Sounds like it could be pretty useful for python scripting.
Got the buffer to work. Now I all I have to do is select those addresses within the buffer, pretty easy from here on out.
This was my first time seeking help on the internet, and it really HELPED.
So once again thank you all, I am now able to finish and graduate with my GIS certification lol.
IanMurray
Honored Contributor
I got a semester of grad school left then off to find a job for me.
EthanHeidtman
im going to be a GIS technician in Cincinnati, so I am sure I will be back
to ask more questions lol .
DanPatterson_Retired
Ian...next time you are channeling... remember the faculty tries hard to keep ahead of the students who are trying to keep ahead of the faculty.... I covered a few of the examples in several of my blog posts which might be useful for students
https://community.esri.com/blogs/dan_patterson/2015/02/20/lesson-5
https://community.esri.com/blogs/dan_patterson/2014/11/16/you-are-not-allowed-to-use-geoprocessing-r...
https://community.esri.com/blogs/dan_patterson/2014/11/13/you-are-not-allowed-to-use-modelbuilder-wh...
JeffWard
Honored Contributor
It looks to me like you are buffering your original feature class (fc).  Don't you want to buffer the selection that you copied into fc + "krogerselection" with your CopyFeatures call?
You could also skip the SelcectByAttributes call by adding your where clause to the MakeFeatureLayer call.
arcpy.MakeFeatureLayer_management(fc, fc_kroger, kroger_selection)
arcpy.Buffer_analysis(fc_kroger, fc + "Buff", "1 Mile")
Jeff Ward
Summit County, Utah
MatthewRusso
put your buffer in the loop and clean go through your logic
EthanHeidtman
what do you mean "and clean go through your logic"Matthew Russo
