Basic Web Printing Script
2275
12-16-2014 07:27 AM
mpboyle
Honored Contributor
I'm not the greatest at decoding python, so I was wondering if someone would be able to tell me if the following Esri tutorial can be applied to multiple map document templates?  For example, I already have a print geoprocessing service created that has multiple templates to choose from.  Is there a way to get this script to apply over all those templates?...or does it work with a single map document?
Thanks!
Basic High Quality Web Map Printing Tutorial
AlexanderNohe1
Honored Contributor
Hi Matthew,
Yes. The way to get this script to apply over multiple templates is to create a parameter in your script tool that would have something like a combo box or a filter added to select which template you would want.  Then when that option is selected, set the templateMXD to that and pass everything else as you would before.
Hope this helps!
