AttributeError: DescribeData: Method spatialReference does not exist
3253
02-20-2016 09:06 AM
RandyBurton
I was experimenting with the following code provided on the Prj File properties documentation page using Desktop 10.3.1 and received an attribute error message.  With version 10.2 the code ran without error.
import arcpy
# Create a Describe Object from a prj file.
desc = arcpy.Describe("C:\data\mexico.prj")
# Print some properties of the SpatialReference class object.
SR = desc.spatialReference
print "Name:            " + SR.name
print "Type:            " + SR.type
print "isHighPrecision: " + str(SR.isHighPrecision)
print "scaleFactor:     " + str(SR.scaleFactor)
It appears that with version 10.3, you should reference the shape file (shp) and not the projection (prj) file for Describe to work properly.
RebeccaStrauch__GISP
I just test with 10.2.2 and received an error with that too.
  Python Shell, prompt 1, line 7
I suggest going to the
on the help page so they can update the code.
RandyBurton
I did "provide feedback" prior to posting this.  My previous test used 10.2.1.
Thanks.
