AssertionError: Invalid MXD filename...why?
5191
05-14-2012 07:29 AM
RichardThurau
I have a simple script for batch exporting .mxds to .PNG:
import arcpy, os ws = arcpy.env.workspace = r"X:\DATA\07_Reporting\MapDocuments\UTC_Factsheet_ANCs" outDir = r"C:\_Rich\Project_Temp\dc\MapTest"  mapList = arcpy.ListFiles("*.mxd") for m in mapList:     print m     mxd = arcpy.mapping.MapDocument(ws + m)     #arcpy.mapping.MapDocument(mxd)     arcpy.mapping.ExportToPNG(mxd, outDir + '\\' + str(m))     del mxd
I've used this code several times before. I don't think I've modified it at all, except for the workspace and outdirectory.
Today, I am getting the following error:
  File "X:\DATA\INRMP_JPG\Tools\Scripts\export_mxd_to_PNG_Smoky.py", line 10, in <module>
    mxd = arcpy.mapping.MapDocument(m)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 443, in __init__
    assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename")
Note: Neither my filenames or mxd names have any spaces in them (although that hopefully would be okay).
I need this bad because i have many maps to convert.
Help on this would be awesome.
Running Arcgis 10.0 sp4
win7 64bit
Rich
MathewCoyle
Honored Contributor
This looks like the problem here.
This would output this
"X:\DATA\07_Reporting\MapDocuments\UTC_Factsheet_ANCsyour_mxd.mxd"
You'd want something like
mxd = arcpy.mapping.MapDocument(os.path.join(ws,m))
MathewCoyle
Honored Contributor
RichardThurau
I'll have to chalk this one up to Monday morning 🙂
Thanks Mathew!!
ClarkMitten
Richard or Matthew,
Do either of you know how to convert this to be used as a tool?
RichardThurau
You can create tools from python scripts following the process here: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001500000006000000.htm
Follow these directions to create a tool that can be saved in any ArcToolbox, which is a great way to organize scripts btw.
Hope this helps.
RT
