ArcPy Update Cursor if/else
8344
15
06-18-2019 03:27 PM
ModernElectric
Good Afternoon:
     I have been doing multiple searches on how to correctly write an if/else statement using Update Cursor to update a specific field based on the criteria in a different field, and lets say I got nothing.
    Looking for a little help on how to write this:
      I have a field called BILLING_MONTH_TEXT (text) and another field called BILLING_DATE (text).
What I need to do is say (As an Example) if BILLING_MONTH_TEXT is May-2019 then it would update BILLING_DATE with a value of 30. If it is April-2019, the value would be 29. And so on and so on.
If I could get started, I can figure out how to fill in the remaining months and values.
Thank You for your help.
ModernElectric
The Convert Time Field tool is being used with a number of other tool(s) in a stand-alone python script that will later be combined into a batch file for easier processing.
The code that I am using to convert the raw READING_DATE field to the text file is this:
      arcpy.ConvertTimeField_management(ELECTRIC_METER_READING_RAWDATA, "READING_DATE", "'Not Used'", "READING_DATE_CONVERT_TEXT", "TEXT", "MM/dd/yyyy;1033;;")
Last time I tried to run it with only about 8,000 rows, it took about 25 minutes to run.
This is what it looks like when its finally done:
JoeBorgione
That's just a concept script; you'd need to take those elements and add them into an update cursor.
JoshuaBixby
MVP Esteemed Contributor
Taking a step back, are you looking to set the billing date on the second to last day of each month?
ModernElectric
I think I am being a little vague on what I am trying to do. I have a table of reading data (approx 15,000 records) of approx 30 months. I have one field that is the billing date (ex. May-2019). The other field is the billing month (ex. 30). Basically, I started with Dec-2016 which has a value of 1, Jan-2017 which is assigned a value of 2 and so on and so forth to May-2019. A previous step uses the Convert Date tool to get the May-2019. This step is to update the Billing Month field based on the value in the Billing Date field.
Hope this helps and makes more sense.
JoshuaBixby
So effectively your final data would look something like:
BILL_DATEBILL_MONTH
Dec-20161
Dec-20161
Jan-2017
June-201819
June-201819
July-201820
May-201930
ModernElectric
Joshua:
   Yes, in a nut shell that would be correct.
I have a series of Model(s) in ArcToolBox that runs my process for me (Billing Data) and it takes several hours to run the process. I am working on transitioning the model(s) to python scripts to make the process run faster and maybe run it automatically through a series of batch file(s).
