arcpy Script that used to work now crashes python.exe (change from SP2 to SP3)
1533
10-25-2011 06:59 AM
RaphaelR
i just noticed that a python script with an ui that works on every computer running arcgis 10 sp2 completely crashes python on a computer with arcgis 10 sp3 installed.
and i have no clue why?
i extracted the part of the code that crashes:
import os
import arcpy
import tkFileDialog
from tkFileDialog import *
myFormats = [("ESRI Shapefile",'*.shp')]
file = askopenfile(filetypes=myFormats,title="Select Input file...")
inFeatures = str(file.name)
print inFeatures, type(inFeatures)
desc = arcpy.Describe(inFeatures)
if "line" in desc.shapeType:
    print "Input Geometry Type: OK - "  + str(desc.shapeType)
else:
    print "Error: Input has invalid Geometry Type - " + str(desc.shapeType)
any suggestions on how to fix this would be appreciated
RaphaelR
the problem seems to be, that when i select an input through a file dialog(have tried tkinter and pyqt so far) it completely screws up once anything afterwards has got anything to do with arcpy (doesn´t even matter if i use the input from the file dialog).
as mentioned the only change on my system was installing SP3, didn´t have that problem before.
import arcpy
import tkFileDialog
print inFeatures
flds= arcpy.ListFields("e:/test/test.shp") #crashes here even though the input file is not used
print flds
GusMartinka
I saw a similar problem with a python script of mine. It ran on a task scheduler ever night for 2 months. The day I installed SP3 it stopped working no other changes involved. I rolled back to SP2 and the script ran fine again.
My script included lots of arcpy with some connections to an SDE (9.3) database.
I think I will just stick with SP2 for now.
Good Luck.
RaphaelR
that´s too bad, guess it´s back to SP2 for me as well then (at least for the time being).
hopefully this will get sorted out.
