arcpy Polyline segmentAlongLine left Dangle Points
1485
07-29-2022 07:01 PM
WentaoChe
I am using ArcGIS Pro 3.0 and Polyline's method: segmentAlongLine to split polylines into equal interval (1 meter). After splitting, I found that there are some dangle points left, and the distances between dangle points are very short, less than 0.0002 meters, some are even shorter, like 0.000005 meters.
I would appreciate it very much if you could tell me why it happened and how to avoid it.
I attach the 3 shp files and the Python script tool:
1. Sample.shp
2. Sample_split.shp
3. Sample_split_Dangle_Error_Points.shp
4. #-Split-Polyline-to-1m-20220730.py
Thank you in advance,
Wentao Che
Tokyo, Japan
DanPatterson
Polyline—ArcGIS Pro | Documentation
shapefiles may not behave as expected because of the warnings.  Use a featureclass in a file geodatabase to check your results to ensure that you have a topologically correct result
... sort of retired...
DanPatterson
WentaoChe
Dear Dan,
Thank you very much for your advice.  I converted my shp files to a featureclass under the Feature Dataset, then segmentAlongLine worked perfectly! No any dangle points left!
Thanks again,
Wentao
