arcpy.mapping.MapDocument("CURRENT")
3318
5
07-29-2011 11:17 AM
MichaelGartrell
MapDocument("CURRENT") returns an error "cannot open map document" if it is not run within an ArcMap session and I understand why.  However, I need to be able to add a layer to the ArcMap TOC from outside the ArcMap application.  How do I best approach that?  Can it be done somehow from python outside an ArcMap session?
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "*")[0]
lyr = arcpy.mapping.Layer(os.path.join(sPath,sFile))
arcpy.mapping.AddLayer(df, lyr, "AUTO_ARRANGE")
JasonScheirer
Esri Alum
Can't be done from Python.
JakeSkinner
Esri Esteemed Contributor
You will just need to specify the path to mxd rather than "CURRENT":
mxd = arcpy.mapping.MapDocument(r"C:\data\Philadelphia.mxd")
After your code, be sure to save your mxd with:
mxd.save()
MichaelGartrell
OK, I half expected that.  Any pointers to how it could be done?
JakeSkinner
Here is an example:
import arcpy
from arcpy import env
from arcpy import mapping
env.workspace = r"C:\temp\python"
mxd = mapping.MapDocument(r"C:\temp\python\Airports.mxd")
for df in mapping.ListDataFrames(mxd, "*"):
    lyr = mapping.Layer(r"C:\temp\python\Airports.lyr")
    addLayer = mapping.AddLayer(df, lyr)
mxd.save()
del mxd
MichaelGartrell
Here is an example:
import arcpy
mxd.save()
del mxd
Thanks JSkinn3 but that will modify an existing document, not the live, maybe unsaved document in a current session.  I need a pointer on how to do that.
