arcpy.GetParameterAsText not working
1561
06-30-2012 11:42 AM
StephenFricke
I have recently upgraded to 10.1 and now the a script which I wrote that worked fine in 10.0 is no longer working in 10.1.  It appears there is an issue with getting the GetParameterAsText function.  Here is there error I am getting:
  File "C:\reacch\scripts\clippedRastoGraph.py", line 6, in <module>
    polygon= arcpy.GetParameterAsText(5)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\__init__.py", line 592, in GetParameterAsText
    return gp.getParameterAsText(index)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 224, in getParameterAsText
    self._gp.GetParameterAsText(*gp_fixargs(args, True)))
RuntimeError: Object: Error in getting parameter as text
Does anyone have any idea why I am getting this error with 10.1 when everything was completely fine when running the script in 10.0?  Thank you!
NobbirAhmed
Esri Alum
What is the data type of your 6th parameter and what value you are trying to assign it? I would like to reproduce the error locally. Thanks.
StephenFricke
I was using a shapefile for the parameter.  I have also tried other parameter types and received the same error.  Let me know if you figure anything out.  Thank you!!
NobbirAhmed
Esri Alum
Have you set your parameter as shown below?
[ATTACH=CONFIG]15641[/ATTACH]
