arcpy.GetParameterAsText not passing arguments to the script
4127
05-29-2019 12:47 AM
HaydenWilson2
I have been working on an arcgis tool which takes the co-ordinate system from an input raster and reprojects a vector to the same co-ordinate system.
The script works fine when i hard code the addresses for the workspace and input datasets. But as soon as I try to pass those as parameters in a toolbox it no longer works.
Can anyone here point out what I am doing wrong?
import arcpy class Toolbox(object):    def __init__(self):        """Define the toolbox (the name of the toolbox is the name of the         .pyt file)."""        self.label = "Toolbox"        self.alias = ""         # List of tool classes associated with this toolbox        self.tools = [Tool]class Tool(object):    def __init__(self):        """Define the tool (tool name is the name of the class)."""        self.label = "Test_tool"        self.description = ""        self.canRunInBackground = False     def getParameterInfo(self):        """Define parameter definitions"""        param0 = arcpy.Parameter(            displayName="Input workspace",            name="workspace",            datatype="DEWorkspace",            parameterType="Required",            direction="Input")        param1 = arcpy.Parameter(            displayName="Input classified raster",            name="input_raster",            datatype="GPRasterLayer",            parameterType="Required",            direction="Input")        param2 = arcpy.Parameter(            displayName="Input features",            name="input_features",            datatype="GPFeatureLayer",            parameterType="Required",            direction="Input")         params = [param0, param1, param2]         return params      def execute(self, parameters, messages):        """The source code of the tool."""         # Define some paths/variables        outWorkspace = arcpy.GetParameterAsText(0)        arcpy.env.workspace = outWorkspace         input_raster = arcpy.GetParameterAsText(1)        input_features = arcpy.GetParameterAsText(2)         output_features = outWorkspace + "\\projected.shp"         out_coordinate_system = arcpy.Describe(input_raster).spatialReference         proj_grid = arcpy.Project_management(input_features, output_features, out_coordinate_system)         return
When I run the tool it provides the following error:
Traceback (most recent call last):  File "<string>", line 75, in execute   File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\__init__.py", line 1245, in Describe    return gp.describe(value, data_type)  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 370, in describe     self._gp.Describe(*gp_fixargs(args, True)))OSError: "" does not exist  Failed to execute (Tool).
it seems to me that the input variables of the parameters are not being passed correctly.
Any advice would be very appreciated.
RandyBurton
It appears that you are using a Python toolbox script (.pyt file) and including GetParametersAsText which works with custom Python script tool.  Comparing custom and Python toolboxes might help clarify some of the differences.
Here is your script with the formatting that Dan Patterson‌ is suggesting:
import arcpy
    def __init__(self):
    .pyt file)."""
    self.alias = ""
    self.tools = [Tool]
class Tool(object):
    def __init__(self):
            name="workspace",
            direction="Input")
            direction="Input")
            direction="Input")
        return params
        return
Since the parameters are defined inside the Python toolbox script (lines 21-45) versus a "wizard" with the custom script, you don't need the GetParameters as text in lines 51-54.  Try replacing lines 47 to the end with:
        outWorkspace = parameters[0].valueAsText
        input_raster = parameters[1].valueAsText
        input_features = parameters[2].valueAsText
        return
Hope this helps.
HaydenWilson2
Apologies. I am not sure why the code formatted like that after I posted it.
Here is the code with better formatting:
import arcpy
def __init__(self):
.pyt file)."""
self.alias = ""
self.tools = [Tool]
class Tool(object):
def __init__(self):
name="workspace",
direction="Input")
direction="Input")
direction="Input")
return params
return
RandyBurton
import arcpy
    def __init__(self):
    .pyt file)."""
    self.alias = ""
    self.tools = [Tool]
class Tool(object):
    def __init__(self):
            name="workspace",
            direction="Input")
            direction="Input")
            direction="Input")
        return params
        return
        return
Hope this helps.
HaydenWilson2
Hi. thank you so much.
That works!
