arcpy.DeleteRows_management fails when feature class has a relationship class
587
12-03-2025 10:18 AM
MichaelTorbett
This just noticed this yesterday. I have a python script that runs nightly. It uses arcpy.DeleteRows_management to delete all of the rows of an enterprise geodatabase feature class. However, yesterday it started failing with the message: arcgisscripting.ExecuteError: ERROR 160083: Failed to delete relationships for object
Failed to execute (DeleteRows).
When I remove the relationship class,  it works fine.
The script runs off of an ArcGIS Pro environment using 3.3.7.
Is there a fix for this issue other than removing the relationship class?
Michael
DanPatterson
MVP Esteemed Contributor
160083: Failed to delete relationships for object.—ArcGIS Pro | Documentation
according to the help for the error, it is a rarely occuring error and you should contact tech support so that the case and its conditions can be assessed as to whether it is an error or a workaround is possible (beyond the one you have currently found)
... sort of retired...
