ArcPy CAD Layers Iteration to GeoDataBase
5455
08-07-2013 02:51 PM
JeffJudycki
I am trying to extract an Ex-Pave layer out of a whole years worth of CAD drawings and I cannot seem to get the code to work
I was able to find the following yet have not had an success. If anyone could shed some light on the error listed below it would be greatly appreciated. Thank you
# Description: Imports and merges polylines from one workspace into a single feature class
# Import system modules
import arcpy
from arcpy import env
env.workspace = "C:\Users\jjudycki\Desktop\Vectren\130103.00 - VEDO 2014 Groups"
# Create a value table that will hold the input feature classes for Merge
vTab = arcpy.ValueTable()
# Step through each dataset in the list
for fd in arcpy.ListDatasets("*.dwg", "CAD"):
    layername = fd + "_Layer"
    # Select only the Polyine features on the drawing layer EX-PAVE
    arcpy.MakeFeatureLayer_management(fd + "/Polyline", layername, "\"Layer\" = 'EX-PAVE'")
    vTab.addRow(layername)
# Merge the CAD features into one feature class
arcpy.Merge_management(vTab, "C:\Users\jjudycki\Desktop\Vectren\130103.00 - VEDO 2014 Groups\VEDO_2014_Drawings.gdb")
File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 322, in RunScript
    debugger.run(codeObject, __main__.__dict__, start_stepping=0)
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\debugger\__init__.py", line 60, in run
    _GetCurrentDebugger().run(cmd, globals,locals, start_stepping)
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\debugger\debugger.py", line 655, in run
    exec cmd in globals, locals
  File "C:\Student\PythEveryone10_1\CreatingScripts\CADtoLayer.txt", line 5, in <module>
    import arcpy
TypeError: 'NoneType' object is not iterable
StacyRendall1
Jeff, how are you running this? Most of the traceback refers to PythonWin debugger, and the last part shows the file "C:\Student\PythEveryone10_1\CreatingScripts\CADtoLayer.txt" as causing some problem.
Can you run it directly from the command line? This will eliminate some of the confusion. Here are instructions on finding your Arcpy Python install and calling it from the command line.
I would also recommend taking a step back and testing your code with lots of print statements i.e.:
# Name: ImportCADandMerge.py
import arcpy
print '1: ', arcpy.ListDatasets("*.dwg", "CAD")
    print '2: ', fd
    print '3: ', layername
This will let you check each part. If the first statement prints 1: None, then there are possibly no *.dwg files in the specified workspace.
JeffJudycki
I was able to run the python script from the command line yet I am still getting similar error 'NoneType' object is not iterable?
Any ideas
[ATTACH=CONFIG]26578[/ATTACH]
And thank you for your help
StacyRendall1
That looks better.
You should read the Docs for ListDatasets. You are calling it with this: arcpy.ListDatasets("*.dwg", "CAD"), but "CAD" is not a valid feature type for this tool, so it returns a value of None.
You can tell that something is fishy because of this in your test:
1: None
That means your next line, for fd in arcpy.ListDatasets("*.dwg", "CAD"): is actually being evaluated as for fd in None:, which doesn't make sense, so it causes an error.
I hope it is clear to you what is actually going on here...
To fix it, you can try the code below. I have just removed the "CAD" part in the ListDatasets, it will default to listing all files with a .dwg extension.
import arcpy
print '1: ', arcpy.ListDatasets("*.dwg")
for fd in arcpy.ListDatasets("*.dwg"):
    print '2: ', fd
