arcpy bold, italic, underline stand alone script
2671
01-03-2012 09:19 AM
deleted-user-MS0lE1F_0-sy
How would I Bold a portion of my text element?  This script loses its next line functionality if I use <BOL></BOL>.  How do I correct this?
finaltext = ("<BOL>Result1:</BOL>" + '\n' + textValue1 + '\n' + " " + '\n' + "<BOL>Result2:</BOL>" + '\n' + textValue2 + '\n' + " " + '\n' + "<BOL>Result3:</BOL>" + '\n' + textValue3 + '\n' + " ")
el1to3.text = finaltext
This script will Bold the Result1 but all the rest of it is jumbled on one line on top of each other.
I would like it to look like this-
Result1:
a
b
c
Result2:
a
b
c
JasonScheirer
Esri Alum
Use \r\n instead of \n
This works great when I use it for one of them:
finaltext = ("<BOL>Result1:</BOL>" + '\r\n' + textValue1 + '\n' + " " + '\n' + "Result2:" + '\n' + textValue2 + '\n' + " " + '\n' + "Result3:" + '\n' + textValue3)
Result1: is bold
However when I switch to it doesnt Bold them:
finaltext = ("<BOL>Result1:</BOL>" + '\r\n' + textValue1 + '\n' + " " + '\n' + "<BOL>Result2:<\BOL>" + '\r\n' + textValue2 + '\n' + " " + '\n' + "<BOL>Result3:<\BOL>" + '\r\n' + textValue3)
the results are:
<BOL>Result1:</BOL>
<BOL>Result2:</BOL>
<BOL>Result3:</BOL>
So it seems like I can only use the <BOL></BOL> once?
Maybe you can tell me or point to some literature on when and how to use \r\n versus \n.  I must be searching for the wrong thing.
I appreciate the help.
Matt
JasonScheirer
Esri Alum
Replace ALL \ns with \r\n and you'll need to use </BOL>, not <\BOL>.
\r\n is the convention for Windows line breaks, \n is for Unix-like systems. In some places in Windows it's forgiving and lets you use \n, but not in text elements.
Got it.  Simple typos always get me.  Thank you for your help and knowledge.
