Arcpy ArcGIS Pro Syntax to Determine if a Layer is Visible in the Table of Contents
5130
6
05-30-2023 11:59 AM
Gene_Sipes
I am trying to write a standalone script for ArcGIS Pro, so that it checks if a layer is visible in the table of contents before running any geo processing functions. I have tried using the following, but it ends up just printing all of the layers in the TOC even if they are turned off, and I get an error stating:
"AttributeError: The attribute 'visible' is not supported on this instance of Layer."
I have tried running it in the Python Window within ArcPro as well, with same result.
# Import ArcPy site-package
import arcpy
# the open records request Pro Project
aprx = arcpy.mp.ArcGISProject(
    r"\\san_marcos\arcfile\Department Projects and File Geodatabases\Public Services\Transportation\GSipes\ProProjects\OpenRecordsRequests\OpenRecordsRequests.aprx")
# list of layers in the project
myMap = aprx.listMaps()[0]
for layer in myMap.listLayers():
    if layer.supports("VISIBLE") == True:
       if layer.visible == True:
           print(layer.name)
print('I am done listing layers')
Gene_Sipes
Alright, got it to work! Edge (ChatGPT) is awesome. Here is my final code, just because. I also realize there is a tool called Extract Data that can accomplish the same thing, but this was more of a python challenge for me than anything. Cheers.
# Import ArcPy site-package and os modules
import arcpy
import os
# Set the clip featureclass
clipFeatures = r"\\san_marcos\arcfile\Department Projects and File Geodatabases\Public Services\Transportation\GSipes\ProProjects\OpenRecordsRequests\OpenRecordsRequests.gdb\SelectionPoly"
# Set the directory path where the clipped shapefiles will be stored
path = r"C:\Users\sipes_gene\Documents\OpenRecords"
# script will ask user to enter new folder name, folder will be place in path
outFolder = input('Enter your folder name :')
# join the path to the new folder name
outWorkspace = os.path.join(path, outFolder)
# Set the XY tolerance of the clip function
clusterTolerance = .000378
# create the directory
os.mkdir(outWorkspace)
    try:
        # check if layer is visible in TOC, if true evaluate against selection polygon
        if layer.visible:
            print('Layer {} is visible.'.format(layer))
            # validate feature class names
            featureClassName = arcpy.ValidateTableName(layer, outWorkspace)
            outFeatureClass = os.path.join(outWorkspace, featureClassName)
            # create a feature layer from layer on disk
            featureLayer = arcpy.MakeFeatureLayer_management(
                layer, "{}_fl".format(layer))
            # evaluate feature layer against selecting polygon
            selectedFeatureLayer = arcpy.SelectLayerByLocation_management(
                featureLayer, "intersect", clipFeatures)
            # get count of selected features for print statement
            count = int(arcpy.GetCount_management(selectedFeatureLayer)[0])
            if count == 0:
                print("%s features do not exist within AOI" % layer)
            else:
                # Clip each feature class in the list with the clip feature class.
                # looks for clip feature so as not to clip it.
                if selectedFeatureLayer != os.path.basename(clipFeatures):
                    arcpy.Clip_analysis(
                        selectedFeatureLayer, clipFeatures, outFeatureClass, clusterTolerance)
                    print("{} {} features clipped to AOI".format(count, layer))
                    print("All is well in the Universe, good bye")
    except Exception as e:
        print(f"An error occurred: {e}")
print('I am done clipping layers to AOI')
DavidPike
MVP Notable Contributor
.supports is a bit flakey I think.
import arcpy
    try:
       if layer.visible:
           print(layer.name)
    except:
        pass
Gene_Sipes
Thanks... well that kind of worked. It at least only prints out the name of the layers that are visible, but I still get a nasty little error.
File "c:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\arcobjects\_base.py", line 90, in _get
return convertArcObjectToPythonObject(getattr(self._arc_object, attr_name))
AttributeError
During handling of the above exception, another exception occurred:
File "\\san_marcos\files\DeptShares\Public Services\Transportation\GIS\Scripts\Python\OpenRecordsRequestReWrite.py", line 15, in <module>
if layer.visible:
File "c:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\arcobjects\_base.py", line 93, in _get
raise AttributeError(
AttributeError
File "\\san_marcos\files\DeptShares\Public Services\Transportation\GIS\Scripts\Python\OpenRecordsRequestReWrite.py", line 18, in <module>
print("error - " + layer.name)
AttributeError: The attribute 'name' is not supported on this instance of Layer.
DavidPike
ah ok, I'll just pass it.  A bit hacky but if it's not production code and it works..  Have edited the previous code above.
Gene_Sipes
I really can't understand why my second print statement never runs. I am slowly building out my code to step along the way. Here I create a feature layer and select records from it that intersect my selecting polygon, but the last print statement: print('just finished selecting features within clip feature'), never runs. Here is the output from the code below:
about to evaluate if layer.visible is true
Layer Centerline is visible.
import arcpy
import os
    try:
        print('about to evaluate if layer.visible is true')
        if layer.visible:
            arcpy.MakeFeatureLayer_management(layer, layer)
                layer, "within", clipFeatures)
    except:
        pass
Gene_Sipes
Ok, made some progress, using {layer} as both the input and output of MakeFeatureLayer seems to be the problem.
Gene_Sipes
import arcpy
import os
    try:
        if layer.visible:
            if count == 0:
            else:
