arcpy.Append_management how to match from/to fields with different names
2962
6
06-25-2019 10:51 AM
JoseSanchez
Hello
How do I match FCFrom field "Point_X"  with  FCTo field "PointX"    before doing an arcpy.Append_management
# Create a new fieldmappings and add the two feature classes.
    fieldmappings = arcpy.FieldMappings()
    fieldmappings.addTable(FCFrom)
    fieldmappings.addTable(FCTo)
    schemaType = "NO_TEST "
   ????  how do I match FCFrom field "Point_X"  with  FCTo field "PointX"
    arcpy.Append_management(FCFrom, FCTo, schemaType, fieldMappings, subtype)
Tags (1)
DanPatterson_Retired
JoseSanchez
I want to populate the field CAPDESC  with  the field "CAP_DESC" .
What am I missing?
I am getting this error message :
ERROR 000800: The value is not a member of TEST | NO_TEST.
   fieldmappings.replaceFieldMap(fieldmappings.findFieldMapIndex("CAPDESC"), fieldmap)
    fieldmap.addInputField(FCFrom, "CAP_DESC")
    fieldmappings.removeFieldMap(fieldmappings.findFieldMapIndex("CAP_DESC"))
 arcpy.Append_management(FCFrom, FCTo, schemaType, fieldmappings)
Jose, you have use "CAPDESC" 3 times, in the code example they used the sequence "TRACT2000""TRACTCODE", "TRACT2000"
Code with line numbers would help
/blogs/dan_patterson/2016/08/14/script-formatting
JoseSanchez
Changed the code:
   fieldmap = fieldmappings.getFieldMap(fieldmappings.findFieldMapIndex("CAPDESC"))
Same error:
Failed to execute. Parameters are not valid.
Failed to execute (Append).
JoseSanchez
Finally I found the error: in the variable   schemaType = "NO_TEST "      the string  "NO_TEST  "  had a space at the end. I removed the space  schemaType = "NO_TEST", and now it works.
 #Target Layer
    fieldmappings.addTable(FCto)
    #Append Layer
    arcpy.Append_management(FCFrom, FCto, schemaType, fieldmappings)
