ArcPy - add multiple shapefiles with for loop
11154
10
02-10-2012 10:50 AM
ZackBartlett
I have a folder that contains a few dozen shapefiles.  I want to create a script that adds all of these files to the current map document.  The script asks the user for a map ID (which decides what folder to load the shapefiles from).
I have the following thus far:
import arcpy, os, glob
# Set Workspace
base_Folder = r"N:\BASE_DATA\CANVEC\1_to_50k"
arcpy.env.Workspace = base_Folder
arcpy.env.OverwriteOutput = True
# User input for NTS mapsheet name.  This variable is also used to search for the correct mapsheet.
map_No = arcpy.GetParameterAsText(0)
# Canvec data is stored in folders, broken down by 1:50000 mapsheet number (eg: 031, 001, 045, etc).
# This variable extracts the folder name to be used when finding the correct folder
folder_Name = map_No[0:3]
# print folder_Name
#Established the correct folder to look in when loading the specified layers.
search_Folder = base_Folder + "\\" + folder_Name + "\\" + map_No
print search_Folder
##mxd = arcpy.mapping.MapDocument("CURRENT")
##dataFrame = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
shp_List = arcpy.ListFiles("*.shp")
for layer in shp_List:
    layer_Path = search_Folder + "\\" + layer
    addLayer = arcpy.mapping.Layer(layer_Path)
    arcpy.mapping.AddLayer(dataFrame, addLayer, "BOTTOM")
    arcpy.RefreshTOC()
    arcpy.RefreshActiveView()
    del addLayer, layer_Path, mxd
I load the script into ArcToolbox.  The script executes without error, but no layers are added to my map document.
I understand there are some redundant or unnecessary lines of code in here, but I think the problem is coming from the for loop.
Any ideas?
DarrenWiens2
That follows pretty closely to this example, which apparently works. The only difference is they refresh TOC after ActiveView, which I doubt matters. When you print layer_Path, does it give the approriate path (including .shp)?
ZackBartlett
I tried stripping down this script in hopes of simply printing a list of the files in the folder and various paths used throughout.  I keep getting hung up on the arcpy.ListFiles()
function.  (I'm running the script in the Python Shell now, not within ArcToolbox as a tool.)
I tried replacing "arcpy.ListFiles" with "os.listdir" and it worked fine.
Here's the error I get:
  File "N:/DOCUMENTATION/PYTHON/Canvec_Symbolization/test2.py", line 44, in <module>
    for layer in arcpy.ListFiles():
StacyRendall1
You must set the workspace, ListFiles lists files within it... I.e.:
import arcpy
# Set Workspace
# print folder_Name
arcpy.env.Workspace = search_Folder
print search_Folder
# list files in workspace
fileList = arcpy.ListFiles()
for file in fileList:
ZackBartlett
This is what I originally thought.  Unfortunately, I want to list files within a subfolder of the Workspace, hence the folder_Name variable, which is then concatenated with other variables to make the search_Folder variable.  The search_Folder variable identifies the folder path I want to list files from (and ultimately add shapefiles to the map document from-see my original post).
-Zack
BenHolmes
RaphaelR
hi Zack,
i think with glob (you even imported it in your code snippet) this should be possible.
http://www.doughellmann.com/PyMOTW/glob/
could you give an example of your exact folder/filename structure?
RaphaelR
made a sample file structure and edited your code a bit:
basefolder\
              031\
                   031L1\
                           --map1.shp
                           --map2.shp
                   031L33\
                           --map3.shp
                           --map4.shp
when typing "031L33" in the tool´s parameter the code below will add map3 and map4:
# Set Workspace
base_Folder = r"e:\test"
#map_No = "031L33"
arcpy.AddMessage("Map Number: " + map_No)
arcpy.AddMessage("Folder Name: " + folder_Name)
# print folder_Name
arcpy.AddMessage("Search Folder: " + search_Folder)
print search_Folder
shp_List = glob.glob(str(search_Folder) + "\*.shp")
arcpy.AddMessage("Shp List: ")
for lyr in shp_List:
    arcpy.AddMessage(lyr)
print shp_List
    addLayer = arcpy.mapping.Layer(layer)
    arcpy.RefreshTOC()
    del addLayer, mxd
hope this helps!
ZackBartlett
Thanks Rafael.  It worked perfectly!
I guess my error was not converting my 'search_Folder' to a string before running the glob.glob function.
ZachErbe
I too am looking to merge multiple shapefiles into one from shapefiles in different directories.
I have only two variables that I want to account for, the base folder "C:\test" and the shapefile that I want to merge, "zones.shp"
The C:\test directory contains thousands of subdirectories with a zones.shp in each subdirectory.
EG:
C:\test
[INDENT]\1001[/INDENT]
[INDENT][INDENT]zones.shp[/INDENT][/INDENT]
[INDENT]\1002[/INDENT]
[INDENT]\1003[/INDENT]
I've attempted to use the code provided above, but am not having much luck.  Appreciate your assistance!
code:
# Set Workspace
base_Folder = r"c:\test"
folder_Name = map_No[1000:9999]
# print folder_Name
print search_Folder
shp_List = glob.glob(str(search_Folder) + "zones.shp")
print shp_List
    arcpy.RefreshTOC()
    del addLayer, mxd
Maybe map_No should just be the zones.shp?
