ArcPro: Python IDE with full code completion
9341
11
03-18-2015 02:16 PM
MatthiasBuehler
I'm on Win8.1 64 bit. I have the latest ArcGIS Pro installed and would like to start diving into Python.
Which IDE would you recommend (Wing?) and how can I set up the full Python code completion in that IDE?
I've seen this is discussed a few times for ArcGIS 10.x with Python 2.x, but not for ArcGIS Pro. I hope I did not miss it.
Any input welcome.
Thanks.
m.
MatthiasBuehler
regarding 3]
I meant license of ArcPy/ArcPro. I have seen some docs where you first need to get a license to be able to run some of the tools, but that is intransparent to me for which tools I would need to do that.
Can you shed some light on this?
Thanks.
Luke_Pinner
MVP Regular Contributor
The help page of each tool specifies what license is required.
For example, the Add Rasters To Mosaic Dataset tool requires a standard or advanced license.
