ArcGIS Attribute Rule $editContext.editType for Split and Merge Operation
1632
08-28-2022 11:11 PM
SU00861536
Hi, I want to implement immediate attribute rule on $editContext.editType for "UPDATE" to generate a new parcel id on splitting of polygons and merging of polygons but not able to find split & merge event in ArcGIS Aracade Expression. I found that Cut(polylineOrPolygon, cutter)  is available for ArcCade Expression. Please if anyone have any idea about ... please share.
JohannesLindner
The Cut() function is for cutting geometries, not for detecting cuts.
$editcontext.editType only returns "INSERT", "UPDATE" or "DELETE". There is no way to trigger the rule only on a merge or cut operation.
A possible workaround could be to detect changes in the geometry:
// Attribute rule to calculate parcel id
// triggers: insert, update
var geometry_changed = $editcontext.editType == "UPDATE" && !Equals(Geometry($feature), Geometry($originalfeature))
if($editcontext.editType == "INSERT" || geometry_changed) {
    var new_id = ...
    return new_id
// If we land here, the feature got updated, but the geometry didn't change
return $feature.ParcelID
But this will calculate a new ID everytime you edit the geometry. So it will only work if cutting and merging are the only geometry edits you do.
Have a great day!
Johannes
SU00861536
Hi
Thanks for the reply.
I am planning to generate new id on the basis of split (UPDATE TRIGGER)  assigning new id using the parent id eg: Polygon ID : 0070 -- Splitted in to two parts so splitted polygon id will be -- 1) 0070_01 and 2) 0070_02.
Same for merging the two polygons 1) 0070_01 2) 0070_02 and assign new id 0071( merged polygon).
I want to find the Split or Merge operation in Arcade expression.
Kindly share some idea to differentiate in Split & Merge operation at Arcade ( already tried Geometry equal & object id equal)
JohannesLindner
This is a way you could handle a split.
// Attribute Rule
// field: ParcelID
// triggers: Insert
// Exclude from Application Evaluation
// An Insert can be a "normal" insert or a Split operation
var id = $feature.ParcelID
var gid = $feature.GlobalID
// no ParcelID -> normal insert, create and return a new ParcelID
if(id == null) {
    var new_id = NextSequenceValue("SequenceParcelID")
    return new_id
var other_parcels = Filter($featureset, "ParcelID = @ID AND GlobalID <> @gid")
// no other parcels with the same ParcelID -> normal Insert.
if(Count(other_parcels) == 0) {
    return id
// else, it's a Split operation
// create and fill an array of updates to the other split parts
var updates = []
var i = 2  // this $feature gets id 1
for(var op in other_parcels) {
    var new_id = op.ParcelID + "_" + Text(i++, "00")
    Push(updates, {globalID: op.GlobalID, attributes: {ParcelID: new_id}})
return {
    result: $feature.ParcelID + "_01",  // the new ParcelID of this feature
    edit: [{className: "TestPolygons", updates: updates}]  // apply the edits   to the other split parts  !!! CHANGE THE CLASSNAME !!!
I have looked for a way to detect merges, but I haven't fond one, yet.
You could just add this Attribute Rule:
// Attribute Rule
// field: ParcelID
// triggers: Update
if(id == null) {
    return new_id
return id
And then delete the ParcelID in the Merge dialog:
Have a great day!
Johannes
SU00861536
Thanks. I will check and update you
