ArcGIS 9.3 python script in ArcGIS 10
3083
8
03-22-2012 06:38 AM
GaneshDevarajan
I need to use the following arcscript on a Linux box running ArcGIS Server 10 SP3
The script is for ArcGIS version 9.3. I am unable to run it in ArcGIS 10
http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=633F4ED8-1422-2418-88B7-3E373...
Any help is appreciated.
MichaelVolz
Esteemed Contributor
Ganesh:
Here are some changes you can make to this script:
Instead of
import arcgisscripting
import os, sys
gp = arcgisscripting.create(9.3)
gp.OverWriteOutput = 1
Use
import os, sys
import arcpy
import arcpy.mapping
from arcpy import env
Instead of
featureClassA = gp.GetParameterAsText(0)
Use
featureClassA = arcpy.GetParameterAsText(0)
Instead of
dscB = gp.Describe(featureClassB)
Use
dscB = arcpy.Describe(featureClassB)
I hope this gets you started to see where you need to make changes in the rest of the code for v10.
GaneshDevarajan
Thank you Michael. I will give it a try.
Ganesh
GaneshDevarajan
Hi Michael,
I made the changes that you suggested and I get the following error..
bash-3.2$ . /usr/apps/arcgis/server10.0/python26/setenv_python.sh
bash-3.2$ python compare_feature_classes.py
  File "compare_feature_classes.py", line 28, in <module>
    import arcpy
  File "/usr/apps/arcgis/server10.0/python26/lib/python2.6/site-packages/arcpy/arcpy/__init__.py", line 17, in <module>
    from geoprocessing import gp
  File "/usr/apps/arcgis/server10.0/python26/lib/python2.6/site-packages/arcpy/arcpy/geoprocessing/__init__.py", line 14, in <module>
    from _base import *
  File "/usr/apps/arcgis/server10.0/python26/lib/python2.6/site-packages/arcpy/arcpy/geoprocessing/_base.py", line 14, in <module>
ImportError: libappinitializerlib.so: cannot open shared object file: No such file or directory
Also attached is the script that I made changes to.
RDHarles
"Arc 9" scripts (gp) will work fine in "Arc 10" (arcpy).  You just won't be able to take advantage of any of the new arcpy functionality.
GaneshDevarajan
If I run the script without making any changes..I am getting the following error...
  File "compare_feature_classes.py", line 27, in <module>
RDHarles
Do you have another computer you can try it on?
I have Arc 10 loaded on all our computers here (at least 8 of them) and doing a "import arcgisscripting" isn't an issue on any of them.
I have to assume your installation/computer is messed up somehow.  All I can tell you is that normally this will work.
ChrisSnyder
Honored Contributor
You said you are running this on a Linux box... I don't have any experience with Server runninng on Linux, but can you start up a Python window (run Python.exe) and run the command:
or
import arcpy
If not, this either indicates:
1. There is something wrong with your ArcServer/Python install
2. You can't run geoprocessing (gp/arcpy) scripts via ArcServer on Linux (I think you can though if I'm not mistaken??)
The error messages you get seem to hint at the 1st possibility.
GaneshDevarajan
Thank you Harles...
Its running...I was trying it on a Linux box and it was unable to find the libappinitializerlib.so.
Running the following script fixed it....
~arcgis/server10.0/servercore/.Server/init_server.sh
