ArcGIS 9.2 - manipulating layers in an mxd
1131
01-13-2011 02:49 AM
LeeMusto
Is it possible write a Python script to work with layers e.g. update definition queries or labels, in an mxd or can it only be done using ArcObjects? Not in a position to upgrade to ArcGIS 10 at the moment, so cannot use the Arcpy.mapping module.
ChrisMathers
To interact with the mxd at 9.2 you need to use AO. Sadly the mxd is not editable at 9.2
LeeMusto
Thanks, I thought that was the case. Will add it to list of reasons why we should upgrade to ArcGIS 10!
