ArcGIS 9.2: can I let a Python script use the work space of the current ArcMap file?
1492
12-07-2010 11:18 AM
SuiHuang
Hi Everybody:
    I am writing a python script to perform data validation for data editor using ArcMap, and want to make it into a tool in ArcToolbox.
    If the tool is executed from ArcMap with a MXD file open, is it possible to let it detect the active data connection in the MXD and directly use it to retrieve data?
    Thank you.
StephenBarrow
Hi Everybody:
    Thank you.
Try
import arcpy.mapping
print arcpy.mapping.MapDocument("CURRENT").filePath
markdenil
Yes, but one cannot evoke arcpy from 9.2, and acgisscripting does not provide access to the arcpy.mapping module.
I do not think this can be done from Arc9.2 in python without accessing ArcObjects.
BruceNielsen
It should be possible to add some VBA code to either an MXD or a user's Normal.mxt that would set an environment variable to the project's source path. That variable could then be read with os.environ.
