ArcGIS 10.2 May I open the attribute table (only the selected features) using arcpy?
4235
05-04-2014 07:27 PM
LiYao
Hi everybody,
I want to open the attribute table (only the selected features) using python, is it possible? If possible, which function should I use?
Thanks.
benberman
Thank you eibenm,
In fact, I am not intend to do after the attribute table is opened.
As user's request, I create a new arctoolbox with several script tools using python. After entering the searching criteria, a table with the selected features data need to displayed on the map in a table format. I am not sure whether I should try to open the attribute table or I should create a table on this. Any body have experience on this?
thanks
Sounds like what you are after is the TableView class in mapping module
http://resources.arcgis.com/en/help/main/10.2/index.html#/TableView/00s300000017000000/
example
import arcpy mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Transportation")[0] accidentsTable = arcpy.mapping.TableView(r"C:\Project\Data\Transportation.gdb\Accidents") arcpy.mapping.AddTableView(df, accidentsTable) mxd.saveACopy(r"C:\Project\Project2.mxd") del mxd, accidentsTable
MattEiben
What you looking to do after the attribute table is opened?
As far as I know, there is no way to open up the graphic attribute table within ArcMap using Python.  If you're looking to search though the data, what you're looking for is a Search Cursor.
The general format looks something like this.
SearchCursor (in_table, field_names, {where_clause})
An example of how you use it:
fields = ["ID","Name","Address","City","Zip","Distance"]
query = "\"Distance\" > 3"
with arcpy.da.SearchCursor("FeatureLayer", fields, query) as cursor:
    for row in cursor:
        print row
The cursor object treats each line of your attribute table as a Python list.  So when each row is printed out, you'll see it as a list.
If you can be more specific what you're trying to do, we can try to help with giving you some more direction.
LiYao
Thank you eibenm,
thanks
benberman
Thank you eibenm,
thanks
example
