Append XML metadata to HTML code using Python
1962
06-25-2013 08:20 PM
CPoynter
Hi All,
I have a script which pulls information from a number of XML files to populate a table within a HTML document.
Although I can pull the information, it is overwriting the table space with the new information. What I would like to do is append the table space (body) of the HTML document for each new XML file, so that I will have a Thumbnail, metadata details for each XML creating a large HTML listing of data for quick reference.
import arcpy, sys import xml.etree.ElementTree as ET  html_head = """  <!DOCTYPE HTML> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <title></title> </head>"""  fh = open(r'D:\Temp\CSD_HTML\file.html', 'wb') fh.write(html_head)  XML_List = [r'D:\Temp\CSD_HTML\test.xml', r'D:\Temp\CSD_HTML\contours.sdc.xml'] for xml in XML_List:     print xml + '\n'     path = xml     tree = ET.parse(path)      for node in tree.findall('.//title'):         title = node.text         print 'Title: ' + node.text      for node in tree.findall('.//westbc'):         westbc = node.text         print 'West: ' + node.text      for node in tree.findall('.//eastbc'):         eastbc = node.text         print 'East: ' + node.text      for node in tree.findall('.//northbc'):         northbc = node.text         print 'North: ' + node.text      for node in tree.findall('.//southbc'):         southbc = node.text         print 'South: ' + node.text      for node in tree.findall('.//geogunit'):         geogunit = node.text         print 'Geographic Units: ' + node.text      for node in tree.findall('.//horizdn'):         horizdn = node.text         print 'Projection: ' + node.text      for node in tree.findall('.//ellips'):         ellips = node.text         print 'Ellipsoid: ' + node.text      html_body = """      <body>     <p> </p>     <table width="800" border="0">       <tr>         <td width="309" rowspan="5"><img src="Thumbs/MitchellD_2013-06-25.jpg" alt="" width="300" height="300" align="left"></td>         <td width="4" rowspan="5"> </td>         <td height="50" colspan="3">Title: """ + title + """</td>       </tr>       <tr>         <td width="150" height="50"> </td>         <td width="165" height="50">North: """ + northbc + """</td>         <td width="150" height="50"> </td>       </tr>       <tr>         <td height="50">West: """ + westbc + """</td>         <td height="50"> </td>         <td height="50">East: """ + eastbc + """</td>       </tr>       <tr>         <td height="50"> </td>         <td height="50">South: """ + southbc + """</td>         <td height="50"> </td>       </tr>       <tr>         <td height="150" colspan="3"><p>Geographic Units: """ + geogunit + """</p>         <p>Projection: """ + horizdn + """</p>         <p>Ellipsoid: """ + ellips + """</p></td>       </tr>     </table>     <p> </p>     </body>"""      fh = open(r'D:\Temp\CSD_HTML\file.html', 'a+')     fh.write(html_body)  html_tail = """  </html>"""  fh = open(r'D:\Temp\CSD_HTML\file.html', 'wb') fh.write(html_tail) fh.close()  del tree
Having an issue getting subsequent tables to add to HTML with each metadata details for each XML file.
Regards,
Craig
ShaunWalbridge
Just open a single file handle, and use that to write all of your data:
Don't reopen the handle throughout the script, it isn't necessary here, and in the last block when you open the file 'wb' you're effectively truncating the rest of the file prior to closing. You can just use the single 'fh' object throughout your script, and be in fine shape.
cheers,
Shaun
ShaunWalbridge
cheers,
Shaun
CPoynter
Shaun's advice solved this for me.
import arcpy, sys
html_head = """
<!DOCTYPE HTML>
<html>
<head>
<title></title>
</head>"""
fh.write(html_head)
XML_List = [r'D:\Temp\test1.xml', r'D:\Temp\test2.xml']
    print xml + '\n'
    path = xml
        title = node.text
        westbc = node.text
        eastbc = node.text
        northbc = node.text
        southbc = node.text
        horizdn = node.text
        ellips = node.text
        html_body = """
        <body>
        <p> </p>
          <tr>
            <td width="309" rowspan="5"><img src="Thumbs/img.jpg" alt="" width="300" height="300" align="left"></td>
          </tr>
          <tr>
          </tr>
          <tr>
          </tr>
          <tr>
          </tr>
          <tr>
          </tr>
        </table>
        <p> </p>
        </body>"""
        fh.write(html_body)
html_tail = """
</html>"""
fh.write(html_tail)
fh.close()
del tree
Regards,
Craig
