append pages to a pdf
6172
02-11-2011 11:47 AM
ChadKeith
Hi
I'm trying to figure out if I can append a bunch of pdfs into a single pdf document.
So I can append the files if I spell out the path and file name of each pdf using pdfDoc.appendPages.
I can also list the pdf files that I have in a folder arcpy.ListFiles("*.pdf").
Now if I could just combine the two functions - so that I'm listing all the pdfs in a folder and then appending them to a new single pdf.
Thanks in advance.
chad
DanPatterson_Retired
did you try
out_file.appendPages(tmp_pdf)
where out_file is an existing pdf and tmp_pdf is another one
ChadKeith
Hi-
I'm not sure how that would help.  I'm probably just not following your logic but here is what I'm try to do with some examples:
It is simple I think - just combine listing a bunch of pdfs from a folder and appending those pdfs in the list to a new single pdf.
Here is the first part:
import arcpy
# Set the workspace.
arcpy.env.workspace = r"C:\output"
# List all of the pdf files in the output folder.
# pdfList is a Python List returned from the ListFiles function.
pdfList = arcpy.ListFiles("*.pdf")
# Iterate through the fields and print the name of each
# field to the Interactive Window.
for pdf in pdfList:
    print pdf
and here is the second part:
import arcpy, os
#Set file name and remove if it already exists
pdfPath = r"C:\output\TimeSeries.pdf"
if os.path.exists(pdfPath):
    os.remove(pdfPath)
#Create the file and append pages
pdfDoc = arcpy.mapping.PDFDocumentCreate(pdfPath)
pdfDoc.appendPages(r"C:\output\1991.pdf")
pdfDoc.appendPages(r"C:\output\1992.pdf")
pdfDoc.appendPages(r"C:\output\1993.pdf")
pdfDoc.appendPages(r"C:\output\1994.pdf")
pdfDoc.appendPages(r"C:\output\1995.pdf")
#Commit changes and delete variable reference
pdfDoc.saveAndClose()
del pdfDoc
ChrisMathers
well if the file names are just numbers like that you should sort the list and then just put the list into a for loop
for file in pdfList:
    pdfDoc.appendPages(r"C:\output\%s"%file)
ChadKeith
thanks this worked perfect!
