append issue - model builder vs python
1192
05-17-2013 08:11 AM
VadivelanPalanichamy
I am trying to append a feature class from fgdb to sde geodatabase.
I created the model builder with append tool, everything working fine.. But after I export the same as python, while executing I am getting the following error.
Error 000732: Target Dataset: Dataset Database connections\schemaowner.sde\schemaowner.featureclass
does not exist or not supported.
Could you help me on this, since model builder is working, but the exported python throwing error, any other lines i have to add.
thanks.
MichaelVolz
Esteemed Contributor
What version of ArcGIS are you working with?
Can you post your code (with code block please)?
Hello Mike,
It is ArcGIS 10.1 Sp1 in Windows 2008 machine.   I tried multiple times, the python code is not working, getting the same error.  I verified the same with different fc.
import arcpy
# Local variables:
inputFC = "inputFC"
SchemaOwner_sdeFC = "Database Connections\\SchemaOwner.sde\\SchemaOwner.sdeFC"
# Process: Append
arcpy.Append_management("inputFC", SchemaOwner_sdeFC, "NO_TEST", "STATUS \"Status\" true true false 1 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,Status,-1,-1;SCORE \"Score\" true true false 2 Short 0 5 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,Score,-1,-1;MATCH_TYPE \"Match_type\" true true false 2 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,Match_type,-1,-1;SIDE \"Side\" true true false 1 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,Side,-1,-1;X \"X\" true true false 8 Double 8 38 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,X,-1,-1;Y \"Y\" true true false 8 Double 8 38 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,Y,-1,-1;MATCH_ADDR \"Match_addr\" true true false 135 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,Match_addr,-1,-1;BLOCKL \"BlockL\" true true false 15 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,BlockL,-1,-1;BLOCKR \"BlockR\" true true false 15 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,BlockR,-1,-1;ARC_STREET \"Street or Intersection\" true true false 60 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,ARC_Street,-1,-1;ARC_CITY \"City\" true true false 40 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,ARC_City,-1,-1;ARC_STATE \"State\" true true false 20 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,ARC_State,-1,-1;ARC_ZIP \"ZIP\" true true false 12 Text 0 0 ,First,#,E:\\ESRI\\work\\work.gdb\\inputFC,ARC_ZIP,-1,-1", "")
MichaelVolz
In the line
In my scripts, this line would be referencing a .sde file.  I am not sure what a .sdeFC file is?
Also, can you provide the full path to the .sde file?  I found that the Database Connections syntax worked for ArcGIS v10.0, but for ArcGIS v10.1 I had to provide the full path for the script to accept the SDE connection file.
I hope this helps.
