Alter Field is not changing the alias name.
4389
12-16-2015 03:12 AM
MarcusSilva1
Example, Original field/alias - STATUS/STATUS. Want to change to: STATUS/Status. The case diference in the alias name is not "seem" by AlterField, so it won't change the alias name.
Has anyone faced this situation already? Any ideas? I was using arcobjects to perfom this task but with this new resource at 10.2.1 I thought I replace the previous approach.
Thanks in advance,
Marcus Silva
LukeSturtevant
I'm having the same issue with the field alias not changing case. I think the only way around this is to change the alias name to something different like STATUS/tempName then back to STATUS\Status.
LukeSturtevant
MarcusSilva1
Thanks Luke,
great idea! I'll try it right away.
Regards,
Marcus
RebeccaStrauch__GISP
Marcus, remember to mark Luke's response as correct if it works for you.  I would have suggested the same type of solution....fieldnames/aliases may be case sensitive in some settings, but when naming/renaming it doesn't seem to ever see a difference.
