Adding python tool output to arcmap automatically when analysis is complete
11496
12
06-18-2012 12:13 PM
IanLeinwand
Greeting all...
I've written a python scrip that is run in arctool box given user specified inputs... at this point the tool works but I would like to have the tool automatically
add the resulting output datasets to the ArcMap table of contents.
I've tried a few variation of the following code... keep getting the same error... see below. I think it all goes back to this line of code where its not recognizing which dataset to add to the map. Any help is appreciated.
Code...
mxd = arcpy.mapping.MapDocument(r"D:\Risk_Models\Sample_Design\sample_design_tool.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "*")[0]
print "ready to add layer"
print sample_plots
newlayer1 = arcpy.mapping.Layer(r"D:\Risk_Models\Sample_Design\Sample_design_tool\sample_design_tool.gdb\state_GA")
#newlayer2 = arcpy.mapping.Layer(sample_points)
print newlayer1
arcpy.mapping.AddLayer(df, newlayer1, "TOP")
#arcpy.mapping.AddLayer(df, newlayer2, "Bottom")
arcpy.RefreshActiveView()
arpy.RefreshTOC()
del mxd, df, newlayer1
end code
Error... reported in python
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript
    exec codeObject in __main__.__dict__
  File "D:\Risk_Models\Sample_Design\Sample_design_tool\FHTET_Sample_Design_Tool\FHTET_sample_design_tool_6_18_2012_add_data_update_test.py", line 94, in <module>
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 255, in __init__
    super(LayerMixin, self).__init__(lyrfile)
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\_base.py", line 47, in __init__
    for arg in args))
ValueError: Object: CreateObject Layer invalid data source
NobbirAhmed
Esri Alum
I created a script with your code and it is working.
What is the data type of "state_GA"?
If you want to persist the added new layer (after you get over the exception) to the map, use mxd.save() before del statement.
Note: don't forget to enclose your code with CODE tabs - click on the '#' button above and paste your code insde the tags.
IanLeinwand
hmm...
State_GA is  a feature class in a geodatabase. Would you mind posting the code you got to work?
thanks
ian
NobbirAhmed
Esri Alum
Here is my code:
import arcpy
try:
    mxd = arcpy.mapping.MapDocument(r"C:\temp\mymap.mxd")
    df = arcpy.mapping.ListDataFrames(mxd)[0]
    newlayer1 = arcpy.mapping.Layer(r"C:\data\redlands.gdb\rdls_street")
    print newlayer1
    arcpy.RefreshTOC()
    # save the map to persist the added layer
    mxd.save()
    print 'Done'
except Exception as ex:
    print ex.args[0]
Which version of ArcGIS (service pack) you are using?
IanLeinwand
I'm still gettin gthe CreateObject Layer invalid data source error. I used your code and just swithched out the path names for my mxd and files. I even tried
different .mxd docs and both a feature class and a shapefile as the layer source.
Not sure what else to do.
NobbirAhmed
Esri Alum
Not sure what's going on. Try both of these:
Make a layer file of your data - in ArcMap, from Table of Content right-click on the layer and select Save Layer as. The file name will have a *.lyr extension.
Use the layerfile.lyr instead of a feature class.
And enclose your code with try-except as in my sample. Write the except block as follows:
    print ex
Let me what error message you get.
DarrenWiens2
Psst! Nobbir, you forgot the "try:" in your previous example.
Ian, the only thing I can think of is that your path is wrong. Later on, there's a typo in your script ("arpy").
IanLeinwand
Okay... not sure if I'm making progress or not... I've simplified the code to try to work out the bug. Here is what I'm working with now.
import arcpy
try:
    mxd = arcpy.mapping.MapDocument(r"D:\Risk_Models\Multi_Species_Sampling\multi_species_overlay.mxd")
    newlayer1 = arcpy.mapping.Layer("D:\\Risk_Models\\state_MN_5000_EAB_plots.lyr")
    print newlayer1
    arcpy.RefreshTOC()
    #save the map to persist the added layer
    mxd.save()
    print 'Done'
    print ex.args[0]
Now the code runs through the arcpy.mapping.Layer line and I do not get the invalid source error like before but the layer still does not add to the specified .mxd and then the new error say...
that it is unable to save the map document.
I have the .mxd open... does this matter.
Ideally I want the users of my tool to have the tool output automatically added to their map document once the tool finishes. Also when I use "CURRENT" for the map document rather than a path it doesn't work. So another question is how do I get it to dynamically recognize the map document the user has created. I don't have any control over what my users name their map documents or where they save them.
Thanks for all the help...
Ian
NobbirAhmed
Esri Alum
If you want to add the layer to the map and show up instantly (while the map is open) then you can create a script tool with the code as the source of the tool. I've attached a tool with the script.
Open the map document you want to add layer. From the catalog window browse to the location where you unpacked the zip file. Double click on the toolbox named AddLayerToMap - you'll see a tool named AddLayerTool. Open the tool by double-clicking on it. The tool dialog is simple - it asks for a layer. The type of acceptable input is a feature class, a map layer or a layer file (.lyr).
[ATTACH=CONFIG]15360[/ATTACH]
Drag-drop any input and hit 'OK'. If everything goes okay then you'll see the layer added to the first data frame.
IanLeinwand
I tried your tool...
when I selected a shape file or feature class... I got the invalid input source
when I tried it with a .lyr file the tool runs but nothing is added to the open map document
I just went back and tried the tool a few more times and its almost like something is added and then immediately disappears.
I would give up on this endeavor at this point but my program manager wants the arctoolbox script I created to automatically add the output dataset to the users map once complete... at this point I feel its easier just to give direction on how to add the data in ArcMap.
