adding multiple fields to features in a geodatabase
7610
12
04-30-2020 11:37 AM
TyquinWashington
I am having trouble trying to add multiple fields to polygon feature classes into a file geodatabase.
Here is the python script I am working with.
import arcpy
#set the environment settings
arcpy.env.workspace = "Z:\\folder\\folder\\Practice\\Practice.gdb"
#Set local variables
fc = arcpy.ListFeatureClasses("Polygon")
#Main Loop to add fields to all Polygon feature classes in file geodatabase
for fc in arcpy.ListFeatureClasses():
    arcpy.AddField_management(fc, "sourceOFData", "TEXT", "", "", "75", "", "NULLABLE", "NON_REQUIRED", "")
    arcpy.AddField_management(fc, "Source Last Edit Date", "DATE", "", "", "75", "True", "NON_REQUIRED", "")
    arcpy.AddField_management(fc, "uploadAuthority", "TEXT", "", "", "75", "", "NULLABLE", "NON_REQUIRED", "")
    arcpy.AddField_management(fc, "effectiveDate", "DATE", "","", "75", "", "True", "NON_REQUIRED", "")
    arcpy.AddField_management(fc, "expirationDate", "DATE", "", "", "75", "", "True", "NON_REQUIRED", "")
    if fc == "DaviePSAP":
        arcpy.AddField_management(fc, "sourcePSAPUnqID", "TEXT", "", "", "254", "", "NULLABLE", "NON_REQUIRED", "")
    elif fc in arcpy.ListFeatureClasses():
        arcpy.AddField_management(fc, "sourceUnqID", "TEXT", "", "", "254","", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "county", "TEXT", "", "", "75", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "state", "TEXT", "", "", "2", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "country", "TEXT", "", "", "2", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "agencyID", "TEXT", "", "", "100", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "serviceURI", "TEXT", "", "", "254", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "serviceURN", "TEXT", "", "", "", "254", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "serviceNumber", "TEXT", "", "", "15", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "agencyVCardURI", "TEXT", "", "", "254", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "displayName", "TEXT", "", "", "60", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "comments", "TEXT", "", "", "100", "", "NULLABLE", "NON_REQUIRED", "")
        arcpy.AddField_management(fc, "gcLabel", "TEXT", "", "", "150", "", "NULLABLE", "NON_REQUIRED", "")
print "Fields have been added to all tables. Good Job!"
I am getting the following error:
  File "C:/Users/Desktop/AddField5.py", line 17, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.6\ArcPy\arcpy\management.py", line 3435, in AddField
    raise e
ExecuteError: ERROR 000622: Failed to execute (Add Field). Parameters are not valid.
ERROR 000800: The value is not a member of NULLABLE | NON_NULLABLE.
I believe the issue is related to the parameters that I have used for the "Date" fields I am attempting to create.  The current syntax works fine for fields that are just "TEXT" types.
Example
import arcpy
    #arcpy.AddField_management(fc, "Source Last Edit Date", "DATE", "", "", "75", "True", "NON_REQUIRED", "")
    #arcpy.AddField_management(fc, "effectiveDate", "DATE", "","", "75", "", "True", "NON_REQUIRED", "")
    #arcpy.AddField_management(fc, "expirationDate", "DATE", "", "", "75", "", "True", "NON_REQUIRED", "")
This code works this way  but I really need the date field arguments to work in conjunction with the added text fields.  Any suggestions?
FYI: Still a novice when it comes to Python scripting.
RandyBurton
You could wrap your AddField with a try/except block. You could then print an error message if there is a problem creating the field.
    try:
        arcpy.AddField_management(fc, "sourceOFData", "TEXT", field_length="75")
    except:
        print "Error creating {} field".format('sourceOFData')
    try:
        arcpy.AddField_management(fc, "SourceLastEditDate", "DATE")
    except:
        print "Error creating {} field".format('SourceLastEditDate')
    # etc.
See Python Try Except for more information.
Another option would be to use ListFields to find out what fields are in your feature and then add those that are not already in the list.
Hope this helps.
TyquinWashington
Thank you very much. I did the try/except block and it works for everything. I really appreciate all the help you gave to me.
JoshuaBixby
MVP Esteemed Contributor
If you have solved or found a workaround for your issue, please mark someone's reply as correct or mark the thread as assumed answered to close it out.
