Adding a feature class to a 3D Layer in Map_3D
2469
09-23-2016 03:16 AM
MatthiasBuehler
[ ArcGIS PRO 1.3.1 ]
I'm a bit stuck with arcpy when adding a feature class in the Map_3D viewer as a layer. Basically I'm trying to emulate the same thing that happens when drag-n-dropping a FC into the Contents pane, resp. the Map_3D viewer.
Code so far ..
import arcpy
aprx = arcpy.mp.ArcGISProject(pPath + pName)
fc = gdbPath + gdbName + '/myFeatureClass'
lyr = arcpy.MakeFeatureLayer_management(fc, 'myLayer')
for map in aprx.listMaps():
   if map.mapType == 'SCENE':
      map.addLayer(lyr, add_position = 'AUTO_ARRANGE')
But this produces an error .. What am I missing?
Thanks for any input!
Matt
DanPatterson_Retired
are your variables defined somewhere else? ppath, pname, gdbpath, gdbname etc
this seems like a question rather than a discussion
MatthiasBuehler
Yes, they are defined as:
pPath            = project Path on disk (e.g. 'D:/..')
pName          = project file name ('.aprx')
gdbName      = path to GDB (usually sitting in the project path)
gdbName      = GDB name
It indeed may be more a question, sorry about that..
matt
Well the reason I asked is because the error isn't specified and there is no way to check what it might be since the error may be due to the values of the parameters.
MatthiasBuehler
Ok, true. This is the error:
File "Y:\..\pyScripts\createCables.py", line 25, in <module>
cc.createCables(pPath, pName, gdbPath, gdbName, pfc, mfc, rpk, lfc, a)
File "Y:\..\cableCode.py", line 456, in createCables
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\utils.py", line 191, in fn_
return fn(*args, **kw)
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\_mp.py", line 1041, in addLayer
return convertArcObjectToPythonObject(self._arc_object.addLayer(*gp_fixargs((add_layer_or_layerfile, add_position), True)))
ValueError: myLayer
Failed to execute (createCables).
