Add Google Maps as a basemap via Python
3379
7
06-17-2025 05:00 PM
AurelienRobert
Hello everyone,
I'm creating customs webmaps  with points and markers using Python.
I'd like to have Google Maps' satellite imagery (https://mt1.google.com/vt/lyrs=y&x={col}&y={row}&z={level}) as a basemap. In the online MapViewer it's easy to add a tile layer from an url but I don't see how to do it through Python.
The guide to use the widget (https://developers.arcgis.com/python/latest/guide/using-the-map-widget/) doesn't mention how to add a layer from an url as basemap, and I didn't find any solution in the documentation or in this questions board.
I've also tried manually creating a layer in the My Content folder of my Arcgis Location Platform but the add tile and add layer features are different from that in the online MapViewer.
Any help appreciated.
Thank you
Tags (3)
AurelienRobert
Replit found the solution: call the Google Maps satellite view as a basemap layer when creating a webmap object.
# Create web map JSON with Google satellite as basemap
sat_url = "https://mt1.google.com/vt/lyrs=y&x={col}&y={row}&z={level}"
webmap_json = {
"operationalLayers": operational_layers,
"baseMap": {
"baseMapLayers": [{
"id": "google_satellite",
"title": "Google Satellite",
"url": sat_url,
"layerType": "WebTiledLayer",
"templateUrl": sat_url.replace("{col}", "{x}").replace("{row}", "{y}").replace("{level}", "{z}"),
"visibility": True,
"opacity": 1,
"subDomains": ["mt0", "mt1", "mt2", "mt3"],
"copyright": "Google"
"spatialReference": {
"wkid": 102100,
"latestWkid": 3857
"initialExtent": {
"xmin": -9548000,
"ymin": 1166000,
"xmax": -9542000,
"ymax": 1172000,
"spatialReference": {"wkid": 102100}
"version": "2.22"
# Create the web map item
create_item_url = "https://www.arcgis.com/sharing/rest/content/users/self/addItem"
item_data = {
'f': 'json',
'token': access_token,
'title': 'title1',
'type': 'Web Map',
'tags': 'test',
'snippet': 'Property map with 6 points',
'text': json.dumps(webmap_json)
response = requests.post(create_item_url, data=item_data)
HaydenWelch
MVP Regular Contributor
You can use the `addDataFromPath` method of a `Map`:
import arcpy
prj = arcpy.mp.ArcGISProject('CURRENT')
m = prj.listMaps('MapName')[0]
lay: arcpy.mp.Layer = m.addDataFromPath(r'https://mt1.google.com/vt/lyrs=y&x={col}&y={row}&z={level}', 'AUTOMATIC')
lay.name = 'Google Hybrid'
prj.save()
AurelienRobert
Thank you Hayden, unfortunately Cursor tells me arcpy can only be imported when using Arcgis Pro, which I do not have as I use a simple Arcgis online account.
HaydenWelch
In that case you'll have to use the Arcgis API for Python. Arcpy is mostly for managing a Pro instance and wrangling tools/data.
The general flow should be the same though.
TonyAlmeida
This works for me, but it's not google maps.
import arcpy
import os
# Get project and map
m = prj.listMaps()[0]  # Gets the first map
# Path to connection file
conn_path = os.path.join(os.environ['USERPROFILE'], 'Documents', 'ArcGIS', 'Connections', 'GoogleMaps.wmts')
try:
    # Add the connection
    lyr = m.addDataFromPath(conn_path)
    lyr.name = "Google Satellite"
    # Refresh view
    aprx = arcpy.mp.ArcGISProject('CURRENT')
    #aprx.save()
    print("Successfully added Esri World Imagery")
except Exception as e:
    print(f"Error: {str(e)}")
    # Alternative legal basemap if Google fails
    world_imagery = m.addDataFromPath(r"https://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer")
    world_imagery.name = "Esri World Imagery"
AurelienRobert
Thank you Tony, unfortunately Cursor tells me arcpy can only be imported when using Arcgis Pro, which I do not have as I use a simple Arcgis online account.
AurelienRobert
webmap_json = {
"baseMap": {
"baseMapLayers": [{
"url": sat_url,
"visibility": True,
"opacity": 1,
"wkid": 102100,
"latestWkid": 3857
"initialExtent": {
"xmin": -9548000,
"ymin": 1166000,
"xmax": -9542000,
"ymax": 1172000,
"version": "2.22"
item_data = {
'f': 'json',
'title': 'title1',
'type': 'Web Map',
'tags': 'test',
TimWestern
Does google allow you to link to its maps from an application with other map sources? I think with 'StreetView' they specifically disallow that in the Terms of Service.
I would be careful about grabbing map imagery from sources you don't have known licenses for, as it could also possibly be a copyright issue.
