As you can see, there are a number of requests package extensions that ship with arcpy.
I have to often deal with client certificates in PKCS12 bundles (.p12 files) in something of an edge case for managing authentication to web services.
requests_pkcs12 is a pure requests extension, well maintained, no problematic dependencies - it would fit easily right along side gssapi, kerberos and oauthlib.
Such an effortless add, and would make my life so dramatically easier - please help!
Thanks for the suggestion. Could you clarify what kinds of servers you need to access in this way? If they are ArcGIS Servers, the Python API today has a PKCS12 story that should work (it was added a few releases ago):
The package itself is really just one file (https://github.com/m-click/requests_pkcs12/blob/master/requests_pkcs12.py), which is about 150 lines if you strip off the tests. It might be easiest just to inline that if you do need direct access to a PKCS12 server outside of an ArcGIS server context, but am interested to hear if there are more nuances that aren't captured yet.
Thanks, Shaun
@ShaunWalbridge Shaun, sorry but I just saw this - I don't get notified for replies for some reason -
Anyway, I work in the federal space, and literally everything is accessed via client PKI certificates. This means that when I write up python toolboxes that integrate with external (non-Esri) web services, a smartcard, .pfx or .p12 bundle is always part of the authentication workflow.
As requests_pkcs12 is sort of the de facto solution for dead simple management of PKCS12, I end up having to have users pip install requests_pkcs12 alongside the main arcgispro-py3 conda instance.
So I would suggest the inverse of what you wrote: if the package is only one ~150 line file, why couldn't Esri just include it along with all of the other extensions to requests that you already include? Thanks for considering!
Although I am not a fan of the Python Requests library, I will second @EricEagle 's comment that support for PKCS#12 in general is very important. It doesn't matter how good software is today in the enterprise if it doesn't have robust support for a range of authentication and access mechanisms.
