How can I update multiple feature class attribute tables with the same values?
3460
05-25-2016 01:12 AM
Dear Xander Bakker,
Please find the attached for the my pgdb.
I am still getting some error from the script you have sent me. please advise. thanks
I have a geodatabase with multiple feature classes in multiple feature datasets.  Each feature class has same fields which are identical and will carry the same value. plzhelp me.
I have fields in the below.
BUILDING_ID
COMMENT
DISCIPLINE_CODE
DRAWING_REFERENCE
FLOOR_ID
OWNERSHIP_CODE
PARCEL_ID
SUBDISCIPLINE_CODE
  1. import arcpy
  2. import os
  3. import sys
  4.
  5. #Set Overwrite Option
  6. arcpy.env.overwriteOutput = True
  7.
  8. # additional parameter to provide the workspace
  9. ws = r"D:\Xander\GeoNet\MultiAttsUpdate\gdb\Sample.gdb"
  10.
  11. # fixed values to assing to fields
  12. building_id = 'your building id'
  13. comment = 'your comment'
  14. discipline_code = 'your discipline code'
  15. drawing_ref = 'your drawing reference'
  16. floor_id = 'your floor id'
  17. ownership_code = 'your ownership code'
  18. parcel_id = 'your parcel id'
  19. subdiscipline_code = 'your subdiscipline code'
  20.
  21. # create a dictionary with the field name and corresponding value
  22. dct_fld_val = {'BUILDING_ID': building_id,
  23.                'COMMENT': comment,
  24.                'DISCIPLINE_CODE': discipline_code,
  25.                'DRAWING_REFERENCE': drawing_ref,
  26.                'FLOOR_ID': floor_id,
  27.                'OWNERSHIP_CODE': ownership_code,
  28.                'PARCEL_ID': parcel_id,
  29.                'SUBDISCIPLINE_CODE': subdiscipline_code}
  30.
  31. # fields to update
  32. flds_upd = dct_fld_val.keys()
  33.
  34. # you have to set the workspace to be able to use the ListDatasets and ListFeatureClasses
  35. arcpy.env.workspace = ws
  36. fds = arcpy.ListDatasets(feature_type='Feature'
  37. fds.append('') # to include featureclasses that are not within a feature dataset
  38. for fd in fds:
  39.     fcs = arcpy.ListFeatureClasses(feature_dataset=fd)
  40.     for fc in fcs:
  41.         # verify that the fields are actually in the featureclass
  42.         fc_pathname = os.path.join(ws, fd, fc)
  43.         flds_fc = [fld.name for fld in arcpy.ListFields(fc_pathname)]
  44.         flds = list(set(flds_upd) & set(flds_fc))
  45.
  46.         # loop through rows of fc
  47.         with arcpy.da.UpdateCursor(fc_pathname, flds) as curs:
  48.             for row in curs:
  49.                 for fld in flds:
  50.                     row[flds.index(fld)] = dct_fld_val[fld]
  51.                 curs.updateRow(row)
Santhosh
Comments
XanderBakker
Esri Esteemed Contributor
It would be best to create a question and not a document, since now comments do not offer the advanced editor to structure code. Below an example of the code that I executed on a copy of your file geodatabase. Note that the bold line points to a location on my drive. You should change this to the location where you have your data.
However, before you do that, be sure what you are doing. Always make a backup of the data before running the script. You data will be updated.
I noticed that there are many attributes the currently have different values which makes sense. By applying a single value to all features you will probably end up with information which is not valid. Your data has information that identifies the different floors.
By assigning a single value to all the feature, they will all be on the same floor...
Be careful with fields that have coded domain values. You will have to assign a valid code (not description).
import arcpy
import os
import sys
ws = r"D:\Xander\GeoNet\MultiupdateAttribs\COSC_SSUC_PGDB_FINAL.gdb"
building_id = '02'
comment = 'MB'
discipline_code = 'FK'
drawing_ref = 'C0400-GS-0114-01-EL-FA-A0-B2-001-999'
floor_id = 'UR' # coded domain - Upper Roof
ownership_code = '99COSC'
parcel_id = '115'
subdiscipline_code = 'GB'
               'COMMENT': comment,
# fields to update
errs = {}
fds = arcpy.ListDatasets(feature_type='Feature')
for fd in fds:
    for fc in fcs:
        print fc
            for row in curs:
                for fld in flds:
                try:
                    curs.updateRow(row)
                except Exception as e:
                    err = '{0} - {1}'.format(fc, e)
                    if err in errs:
                        errs[err] += 1
                    else:
                        errs[err] = 1
for err, cnt in errs.items():
    print err, cnt
santhoshp
Dear,
It's working above the code.
Thank you so much your help.
Santhosh
Version history
Last update:
‎05-25-2016 01:12 AM
Updated by:
Contributors
