Spanning trees
3820
8
01-31-2017 09:01 AM
DanPatterson_Retired
4 8 3,820
Connecting the dots.  Spanning trees have a wide variety of applications in GIS... or did.  I have been finishing writings on distance and geometry and I almost forgot this one.  The principle is simple.  Connect the dots, so that no line (edge) overlaps, but only connects at a point.  In practice, you want the tree to produce a minimal length/distance output.  There are a variety of names forms, each with their subtle nuance and application, but my favorite is Prim's... only because I sortof understand it.  I am not sure if this his implementation exactly, but it is close enough.  So I post it here for those that want to try it.  Besides, Prim's can be used to produce mazes, a far more useful application of dot connection.
My favorite code header to cover imports and array printing and some bare-bones graphing
import sys
import numpy as np
import matplotlib.pyplot as plt
from textwrap import dedent, indent
ft = {'bool': lambda x: repr(x.astype('int32')),
      'float': '{: 0.1f}'.format}
np.set_printoptions(edgeitems=10, linewidth=100, precision=2,
                    suppress=True, threshold=120,
                    formatter=ft)
np.ma.masked_print_option.set_display('-')
script = sys.argv[0]
Now the ending of the script where the actual calls are performed and an explanation of what is happening occurs.
if __name__ == "__main__":
    """Main section...   """
    #print("Script... {}".format(script))
    # ---- Take a few points to get you started ----
    a = np.array([[0, 0], [0,8], [10, 8],  [10,0], [3, 4], [7,4]])
    idx= np.lexsort((a[:,1], a[:,0]))  # sort X, then Y
    a_srt = a[idx,:]                   # slice the sorted array
    d = _e_dist(a_srt)                 # determine the square form distances
    pairs = mst(d)                     # get the orig-dest pairs for the mst
    plot_mst(a_srt, pairs)             # a little plot
    o_d = connect(a_srt, d, pairs)     # produce an o-d structured array
Now the rest is just filler.  The code defs are given below.
def _e_dist(a):
    """Return a 2D square-form euclidean distance matrix.  For other
    :  dimensions, use e_dist in ein_geom.py"""
    b = a.reshape(np.prod(a.shape[:-1]), 1, a.shape[-1])
    diff = a - b
    d = np.sqrt(np.einsum('ijk,ijk->ij', diff, diff)).squeeze()
    #d = np.triu(d)
    return d
def mst(W, copy_W=True):
    """Determine the minimum spanning tree for a set of points represented
    :  by their inter-point distances... ie their 'W'eights
    :Requires:
    :  W - edge weights (distance, time) for a set of points. W needs to be
    :      a square array or a np.triu perhaps
    :Returns:
    :  pairs - the pair of nodes that form the edges
    if copy_W:
        W = W.copy()
    if W.shape[0] != W.shape[1]:
        raise ValueError("W needs to be square matrix of edge weights")
    Np = W.shape[0]
    pairs = []
    pnts_seen = [0]  # Add the first point
    n_seen = 1
    # exclude self connections by assigning inf to the diagonal
    diag = np.arange(Np)
    W[diag, diag] = np.inf
    while n_seen != Np:
        new_edge = np.argmin(W[pnts_seen], axis=None)
        new_edge = divmod(new_edge, Np)
        new_edge = [pnts_seen[new_edge[0]], new_edge[1]]
        pairs.append(new_edge)
        pnts_seen.append(new_edge[1])
        W[pnts_seen, new_edge[1]] = np.inf
        W[new_edge[1], pnts_seen] = np.inf
        n_seen += 1
    return np.vstack(pairs)
def plot_mst(a, pairs):
    """plot minimum spanning tree test """
    plt.scatter(a[:, 0], a[:, 1])
    ax = plt.axes()
    ax.set_aspect('equal')
    for pair in pairs:
        i, j = pair
        plt.plot([a[i, 0], a[j, 0]], [a[i, 1], a[j, 1]], c='r')
    lbl = np.arange(len(a))
    for label, xpt, ypt in zip(lbl, a[:,0], a[:,1]):
        plt.annotate(label, xy=(xpt, ypt), xytext=(2,2), size=8,
                     textcoords='offset points',
                     ha='left', va='bottom')
    plt.show()
    plt.close()
def connect(a, dist_arr, edges):
    """Return the full spanning tree, with points, connections and distance
    : a - point array
    : dist - distance array, from _e_dist
    : edge - edges, from mst
    p_f = edges[:, 0]
    p_t = edges[:, 1]
    d = dist_arr[p_f, p_t]
    n = p_f.shape[0]
    dt = [('Orig', '<i4'), ('Dest', 'i4'), ('Dist', '<f8')]
    out = np.zeros((n,), dtype=dt)
    out['Orig'] = p_f
    out['Dest'] = p_t
    out['Dist'] = d
    return out
The output from the sample points is hardly exciting.  But you can see the possibilities for the other set.
This one is for a 100 points, with a minimum spacing of 3 within a 100x100 unit square.  Sprightly solution even on an iThingy using python 3.5
Now on to maze creation .....
8 Comments
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
